Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Greg,
Thanks for testing that. Indeed the descents in Loiter/AltHold do look more stable using AC3.3.
place in video when descending with AC3.2.1 is here
equivalent for AC3.3-rc1 is here.
What was the WPNAV_SPEED_DN value set to?
Hi David,
The landing gear is semi-automatic at this point. It will not raise itself automatically yet, you must raise it manually. Eventually we'd like this to be a mission command. But we need more user input for use-cases, etc Making it go up automatically is slightly risky. When/how would we do that? Altitude? What happens if somebody goes to land on a hill far away? So all of this requires some work still.
However, the landing gear will lower automatically. You can of course use the switch, but then it will also deploy the landing gear in the descent phase of RTL, or anytime in Land mode. The main point here, is if you have a radio failsafe and don't have control of the copter, it will lower the gear.
RB
RB, I personally don't have the Zubax so I don't have much of a clue why it wouldn' work but I've ping'd Tridge (who is as far as I know the only person on the dev team to use it) so he might be able to provide some advice).
Thanks for getting back to me. Pavel is looking into it as well. As far as the APM Planner accelerometer issue, I have tried 4 different Pixhawks with the same results, when I revert to 3.2 calibration proceeds as normal. Probably a small issue with APM Planner. I submitted a github post on the APM Planner page.
RB,
So according to Tridge, getting the Zubax GPS to work should be as easy and just plugging it in. To help debug the issue could you try this?
Connect with the MP's terminal screen, Connect for PX4/Pixhawk and when the console appears type:
Then stick the results here.
By the way, while coming up with these instructions I had some problems getting to the console through the MP's Terminal screen but I got there eventually after trying varying combinations of the connect button and connecting/disconnecting the pixhawk. We might have an issue there we need to investigate with MichaelO.
Randy,
After setting GPS_TYPE to 9 all is well on the UAVCAN Bus. Short test flight this morning with the Zubax GNSS and it works very well.
Thanks for all your help
Randy,
Thanks very much for digging into that Zubax GPS issue and figuring out that we must set this parameter: GPS_TYPE = 9.
As mentioned on the github discussion I've updated the parameter description for the GPS_TYPE param to be "PX4-UAVCAN" so hopefully for the next Zubax GPS user will find this more easily.
Randy,
When you say the Zubax works very well, can you elaborate?
