Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
          It looks like a brownout in that the logs just suddenly stop.  We don't actually have a way to distinguish brown-outs from catastrophic firmware failures although we're working on a way... but normally when the logs just end like this it's a brownout in these cases and the board voltage is indeed very high at 5.7+ volts.
          I think Jesus is correct when he says it will fall back to the power module if the power rail voltage goes too high.  Maybe you weren't using a power module?
          • No i was  not using a power module. I am running 12S, so i have the 180A atto pilot in there. but without a bec on the 5v and gnd wires to the pwr module port.
  • Here is the flight log. failure mode (drift) is in first flight. Video of the flight here. Thank you.
    log alien 1.rar
  • @paul riseborough
      Thanks for your quick reply.
  • Maybe a silly question?
    After dropping support for APM, why don't you declare the new line as 4.0.x version? On the long run, maybe we (APM users) will get some bug/security fixes and then 3.3 could lead to a lot of confusion?
    Best c.
      Someone else made that suggestion as well.  Personally I think the differences between AC3.2.1 and AC3.3 are not so large that it deserves the major version number increase.  For the APM boards, if we do a patch release we will call it AC3.2.2, AC3.2.3, etc so only the last (most minor) number would be increased.  We wouldn't call it AC3.3.
        Dropping the 8 bit support is not a good reason for a major revision number change.
      • - 8-bit dropped, 32-bit+ only
        - mainstream linux support (new for 3.3?)
        - EKF, EKF, EKF
        - SOLO support
        surely worth a major version bump - if not for this, then what :)
          There is a good argument for bumping up the version, some others on the dev team are keen to do this as well but personally I like the idea of saving the major version bump for what you mentioned which is the main stream linux support.  It's almost there but I think it's still a fork of the main code.  Certainly there are a bunch of (non-critical) features that don't work on the Linux boards yet but more than that we really haven't sorted out an easy way to load firmware onto the linux boards.
          Also ideally I'd like to bump the version up in coordination with Plane if possible... and their move to Linux would happen at the same time because we share so much of the same code (most of the libraries)
          • Randy, you have a good point here.
            As my main job is a software project manager I think there is a need to somehow clearly distinct the two versions. As MS (and others me included) do when there is not enough reasons for a major version change, they name it X.5,
            IMHO a 3.5 version would be a clear enough distinction over the 3.3.
            Just my 2 cents.
