Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Okay, so its been a rough week for my birds.
Just had a crash on 3.3rc1 with a y6b. I was doing some fast circles when all of a sudden it went out of control and crashed to the ground. Looking at the logs I think I cracked/broke a prop in flight as the vibrations rose quite a bit right before the crash.
Here is the log.
2015-04-24 09-55-37.log
Sorry, I missed that you were trying to tune R/P I. But perhaps you forgot to set the limits for tuning (high/low)? They both are set to 0.
Interesting.... I had just finished tuning rate I and all was fine, then i was flying around once i had it tuned. I didnt touch the ch6 knob though before it crashed. I had this problem right before I flew it to tune. The low/high values did not stick. I had to set it all again right before I took off.
Have a look at your tlog and see if the command to set the parameters was sent.
I don´t think your crash is caused by vibrations.
Your PIDs look a little strange - did you get them from autotune?
@Randy - Hi, thank you for the help the other day with vibrations, I replaced the FC mounting foam and it fly's just great! Are we likely to see RC2 this weekend? Cheers! Mike
Sorry just noticed you're earlier comment - oops!
Hi Guys anyone know about 3dr Telemetry not connecting after upgrading to 3.3 or even 3.2.1. ?? was working fine before messing with firmware .. I know the units work as I can swap between machines ..?? Ideas
3DR Telemetry (at least the original one V2) is working with both versions. Some guys reported, that it is sometimes required to re-power the unit, to get a connection. But I doubt, that the FW is responsible for this. Downgrade to 3.15 to verify this.
What telemetry radio are you using and which ports on your auav-x2
? I have a RTFQ radio and can't connect using mavlink.....really frustrating.
422
423
424
425
426
of 449 Next
