Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
So given that I've been proved correct on this issue I'm tempted not to reply, but there are some assertions you make that I'm not sure I understand so I'll dig a little.
I'll note in passing that I did not start the thread in drones-discuss I merely followed up with a report, patch and pull request that highlighted the issue. If that was not on topic enough then IMO your bar is too high. I would kill for that sort of customer feedback to my own software development team.
So back to the GPS, so I think I was under a misapprehension here - assuming that the gyros are calibrated when the accels are calibrated, but of course they are not. Why is the GPS used in the calibration at all? I can fly without a GPS, and I'm guessing I always need gyros so its certainly possible to calibrate without it - so what is the GPS adding to the equation? Also, when the Gyros calibrate at power up there is never a GPS lock, so using the GPS seems erronous, so why would you?
Andy, I'm really impressed that you actually went and made some effort to fix a problem and then went and made a pull request.
Thank you. I really appreciate your effort and your contribution.
I didn't realize the group was for developers. Are my issues with 3.3's autotune and gps health off topic? Don't want to bog you guys down lol! At least there's answers unlike to olds days of flying DJI : )
Shaun,
The drones-discuss@googlegroups email group is mostly for developers but this thread is all about AC3.3 beta testing. So this is the best place to raise issues related to AC3.3's autotune.
AC3.3-rc4.
Quad with Pixhawk RFdesign telemetry, clean power to Pixhawk (no switching power supply). M8N external GPS/compass.
Arming is ok but then..
Got EKF variance message..
then Bad gyro health..
then these messages go away.. Not sure if it is a real problem or not..
(perhaps not the right spot to ask but just in case: Is it possible to return home instead of launching {arming} spot?)
Thank you.
Henri
Craig,
thanks for the info! Makes sense!
Can you give some value/threshold of the velocity error allowing gyro calibration?
Tarrot 680 Pro (hex), Emax 3510's and 1355 Carbon on 4s flew faultless 'out the box'. Ahead of the flight I redid the compass, flights modes and accelerometer, that's it - everything else I as stock as I had completely erased everything from before. I noted on the bench the Altitude seemed very accurate, I am yet to review the logs from the flight but by eye it all seemed great - Stab, Althold, Loiter and PosHold. I didn't do an auto tune as it was very gusty.
Brilliant work, thank you!!!!
Was that for me? I have 2 on board; 3DR LEA-6H with compass and a New Ublox 8M
Log File C:/Program Files (x86)/Mission Planner/logs/HEXAROTOR/1/2015-05-17 11-38-30.log
Size (kb) 7422.033203125
No of lines 97858
Duration 0:06:13
Vehicletype APM:Copter
Firmware Version V3.3-rc4
Firmware Hash f4ad23b9
Hardware Type
Free Mem 0
Skipped Lines 0
Test: Autotune = NA -
Test: Balance/Twist = NA -
Test: Brownout = GOOD -
Test: Compass = GOOD - mag_field interference within limits (10.34%)
Test: Dupe Log Data = GOOD -
Test: Empty = GOOD -
Test: Event/Failsafe = GOOD -
Test: GPS = GOOD -
Test: IMU Mismatch = GOOD - (Mismatch: 0.38, WARN: 0.75, FAIL: 1.50)
Test: Parameters = GOOD -
Test: PM = NA -
Test: Pitch/Roll = NA -
Test: Thrust = NA -
Test: VCC = GOOD -
Cheers, Mike
Great job team!
Thank's
We've started on updating the docs. So far we have:
398
399
400
401
402
of 449 Next
