Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Bill, can you please post the log file with your test. None of us have actually tested it in a mission so it is quite possible it does not work.
I was pretty excited to try the new autotune in 3.3rc3 with yaw, but what I got was strange. My Rate Roll was .32 .93 .021 and Pitch Rate was .28 .71 and .02. Make for a really shaky flight. Before I was at RR .25 .1 and .004 which seemed to fly fine. Strange thing is I found that autotune in 3.2 would match the P and I values and now the I values are way higher than the P's. I've heard from others the I value should be lower than the P. The yaw seems pretty good, aggressive but works well.
3.3rc3
Pixhawk
Tarot T960
Foxtech 5101 motors
DYS40a esc
18" props
6s22,000 battery
6.8kg
There seems to be a problem with auto analysis of logs produced by 3.3 in MP. I get errors saying "NSats" and then "Bad input file" and no auto analysis. 3.2.1 is fine. I put an issue here https://github.com/diydrones/ardupilot/issues/2306
andy
Thanks for the all the work with the updates.
I just loaded RC4 and now getting a Bad Gyro Health warning on mission planner. RC3 worked fine.
Any suggestions?
Me too...on both multi with original Pix I have...gps is 20 cm or so away...
"Read the ublox binary format specification and learn how to find and interpret the noise, jamming indicator, and agc values in the UBX1, UBX2, UBX3 messages as well as the estimated position and velocity errors reported in the log"....?????
I didn't know we all have to be experts in gps electoronics to be able to fly our multirotors
When did you buy your pixhawk?
I was getting bad gyro health yesterday as well. Not there today. Stange.
You could try my patch to see if you get these in flight: https://github.com/diydrones/ardupilot/pull/2284
If you want I could put up a build of rc4 with this in.
I believe this Pidhawk is about a year old. I've got so many it's hard to keep track lol. I presume this patch is added to record GyrHlt and AccHlt under the IMU section... Yea, I have no idea lol! Just have to learn how to add a patch of code the the current build.
It would be a good data point to know which IMU is failing. For me it is IMU2 which I believe is the lsm303d which makes no sense to me, since re-reading the "Bad Accel" thread it's clear that the MPU6K is the culprit and lsm303d issues only occur on non-3DR boards. Is yours a genuine 3DR pixhawk? Could it have been purchased in July 2014 (I know that's a bit less than a year, but that was the start date of the bad batch).
Maybe this is just software, but it is something since there are three of us (at least) with this issue.
confused!
