Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
All right, being fueled by so many great responses on AC3.3 autotune, I decide to give it a try last nigh on one of my machines. It is a large-ish (750 size) tricopter running on 6s lipo. Took off the gimbal, put a dummy weight in its place, made sure nothing is able to move on the air-frame and went to the park to do the autotune. I can say that the values autotune returned on pitch and roll are definitely not ideal, but certainly flyable, on the other hand yaw is a total miss, much delayed reaction + big overshoot. Need to say that the last firmware which gave good PIDs for any tricopter was 3.1.5, is there any way to take the best from 3.1.5 into 3.3?
Thank you!
edit: here is the link to the log https://drive.google.com/open?id=0ByNP743-FSrrd2ZaVjNxLXRqdzQ&a...
Hi Artem,
Could you provide some logs and a couple of photos of your tri.
I have not tested auto-tune on tri's but I am about to build one so any feedback you can give would be great.
here are the pictures: http://www.rcgroups.com/forums/showpost.php?p=30895667&postcoun...
the ****hawk is replaced now with AUAV-X2
Hi Artem,
Yeh, sorry about how long it has taken me to build a tri. I have ordered another one that should be pretty similar to yours without the gimbal. The frame I had was going to be a pain in the .... to mount the pixhawk on and the tail servo arrangement sucked.
The tune you supplied looks good for roll and pitch. I suspect that a big part of your problem is you have RCFeel set to 100. I would suggest dropping it to 25 or 50.
On the yaw tune. Again Autotune looked like it did an ok job of it. However it wasn't designed to handle tri's. When the cg of the rear motor is higher than the pivot point the copter rotates slightly in the wrong direction before starting to rotate in the correct direction. I haven't tried to approach this problem yet.
Could you give me an example of your yaw tune with parameters you think are good vs the ones from your last tune.
Thanks!
HI leaonardt, thank you for looking into this. You might remember we already spoke couple of time regarding autotune on tricopters. Couple questions, do you need some of the regular logs as well, or only those with autotune?
I will reattach the 3.3 rc4 autotune log here.
edit: and last 3.2.1 atotune as well
2015-05-20 18-47-20.7z
2015-05-20 14-10-58.zip
A couple more tests on the bench.
As suspected, once the unit warms up, a power reset shows less altitude deviation, it only climbs to about a meter in a couple of minutes and stabilizes. But it doesn't reset on ARM.
This problem was already present in 3.2.1 as you can follow here:
http://diydrones.com/group/arducopterusergroup/forum/topics/buildin...
Have a look at:
https://github.com/diydrones/ardupilot/pull/2310
there is hope :-)
A bump on my problem of 12 hrs ago.
I see that the altitude drift after initial boot isn't reset on arming. Is there something new there?
Yesterday, I took off from +3m and landed at 9m. This would affect autoland. (in this case I did a manual land.
WHen I tested on the bench, the altitude read near 12 meters after only about 5 min. It didn't reset on ARM.
This last test was indoors without GPS, however a similar result occurred previously outside with HDOP of 1.3
Anybody know what's going on?
I'm going to fly today. I'll try letting it "settle down", then reset power, its shouldn't deviate much from zero on the ground, but that's not a reasonable fix.
Hi
I have done autotune with v3.3 r/c4 twice now and notice that rate P and rate I are identical in roll and also in pitch, (5 decimal places ) coincidence?, part of the algorithn ,or bug?
any way my Y6 flies so sharp and crisp now I am very pleased Thanks all.
Tim Painter
384
385
386
387
388
of 449 Next
