Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
I don't re-do the calibration or refresh the parameters very often and we're pretty careful to not make any changes that would require re-doing the calibration or parameters unless it's absolutely necessary. It can't hurt but it shouldn't be necessary.
Randy, when we do primary compass calibration - does it overwrite previous data from motor/compass interference level?
If you do not mind me asking - what specific parameters holds this info and what item on logs shows level of that interference during flight? I want to try to do some EMI shielding for Tarot but not sure what are the measures to control and monitor.
Is there anything in the 'status' window to see real time data for that?
Hey Paul,
The compass calibration updates these parameters:
COMPASS_OFS_X, Y, Z
COMPASS_OFS2_X, Y, Z
COMPASS_DEV_ID <-- recorded so that we know which compass was attached when cal was done
COMPASS_DEV_ID2
..but it doesn't update the motor/compass interference calibration results though (held in COMPASS_MOT_*). If the compass is completely changed, then the compass-mot should be re-done as well. If it's the same compass and the power wires, etc haven't been moved around then it's probalby ok not to do the compass/motor interference calibration.
I agree.
I was a little in a hurry when I installed RC6, and almost paid a price for it.
Fortunately, one of my quad motors sound a little different, so I decided not to take off at all before I sort that out.
Long story short, I had to do all of the calibrations (radio, ESC, accel, compass), before it started to behave.
Later today I will install RC7 and redo the calibrations again.
It only takes a couple of minutes but it's really worth.
Hi Randy, Leonard and the rest of the beta testers,
I have been patiently waiting and following this thread hoping to find a solution to my problem running 3.3. I see that there has been a great deal of improvement but I am still getting the same issue. That is, EKF Error as soon as I arm that will not clear. (Same on all of my machines, with or without peripheral equipment attached or running)
Here is a log with a very short hover, I was hoping the error would clear. 3DR support had a look at my 3.2.1 logs and could not see a problem so I am putting this here in the hope that the development community can see if there is a problem with the code or strictness of parameters.
I did notice that several of the EKF readings in the logs are flat lined if that helps narrow it down,
Anyway, back to waiting and thanks for all of the work you guys and girls do!!
https://www.dropbox.com/s/4x3zdkxeo5yalt3/2015-06-29%2014-42-14.bin...
Hi~ I found a small problem,when PIXHAWK use 3.3rc6 start than external LED lights turn in blue flash,it means we can arm,but my radio is not open yet,And then I used Mission Planner find than RC failsafe.and this problem,can solve by open and close radio power,external LED turn in yellow flash.but next time start up PIXHAWK the problem came again.
RSM_LI,
I think I found and fixed the problem today and it will go out with -rc8.
Is it possible that the Terminal (CLI) is not working since AC3.3?
I would like to try AC3.3 but since rc5 (the first -rc I tryed) I got this:
Andre,
It's disabled because you should be able to do everything you need (log downloads, compassmot, etc) using new MP features that use MAVLink instead. If you really want to use the CLI there's a new parameter called CLI_ENABLE that can be set to "1". The CLI itself has been cut down massively though so many featuers are gone from it. We did this because it eats up developer and testing time to maintain multiple methods of doing the same thing.
Randy,
is there any other tool available where one can easily select what should be logged? This was prefect with the CLI.
