Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • I have done quite similar experiment with tarot frame I play with now - as in armattan I used bobbing and foam to suspend FC case and on tarot it is bolted to the top frame plate in the dead center of the system. only damper I used was a 1mm think special rubber spiderweb like compound that was applied to all connections of the upper plate to the rest of the frame parts. I think it did the trick well.
        it may be related to overall hex preference over quad but it operates way better than armattan, it is much more precise. I am tempted to take armattan apart now and fix mount FC case in a same way so IMUs inside will not have any side effects from the mini vibrations of the case on the suspenders.
        it is somewhat similar, in fact, to the problem of removing jellow from the video feed - too soft of a damper system causes more harm than good.
  • A question about the Storm32 serial setup:
    For me it seems to be not possible to setup manual RC control as done with mavlink. Do I do anything wrong or is it still not supported? I am using storm firmware 0.82e.
    3.3RC7_letzterStand.param
    letzter Stand.cfg
      Gregmaan,
      So it looks like it's setup to use the SToRM32 serial protocol and you're planning on controlling the mount's tilt with the transmitter's channel 11 and the pan with the transmitter's channel 6.  Looks like you've probably followed the instructions on the wiki because the SERIAL2 baud and protocol look to be set correctly.
      I guess you're saying that the gimbal doesn't move when you move channel 6 and 11 on the transmitter?
      • Randy, I started separate thread for that question -
        http://diydrones.com/forum/topics/need-step-by-step-guide-for-storm...
        if you`ll have time could you pls respond there so we would not pollute this thread with storm32 stuff?
          Paul,
          Ah, thank you very much for that.  As mentioned over there, I think the best idea is to try and get either the MAVLink or Serial protocols working instead of introducing a 3rd protocol to control the gimbal!  Two protocols is surely enough!
      • I also got this board and so far unable to make it talk with AUAV board.
        I know storm32 board can be also connected via SBUS - how can it be done exactly if serial connection does not work out?
        Also, what and how can be done to make serial 4 port to appear? I understand serial 5 is by default mapped into output, but can be swapped by serial4?
      • Yes thats exactly my problem. Sorry for my poor explain
  • I have been trying to get my hex back up in the air but one thing that I was hopeful to use in this new firmware is the sbus output. I have enabled the parameter as directed on drones discuss but I don't seem to be getting any output from my pixhawk. I need to be able to run the sbus out to control my alexmos gimbal pitch ,yaw, and shutter control. The alexmos picks up sbus from my receiver if plugged in directly so I do know that the alexmos isn't the problem, but there doesn't seem to be any sbus output from the pixhawk on any of the encoded sbus channels. Is this functionality supposed to work in 3.3?
    • Found my issue. It seems that the sbus output doesn't enable until the safety switch is armed. Once armed, it seems to allow sbus out for output channels 1-8. It would be nice if sbus out would work without pressing the safety switch.
      What would also be nice is to have additional channels in sbus out. For a hex, I only have 2 channels not tied to escape outputs. Channel 8 out easily links with my camera pitch control, but I also need a pass through for my camera shutter. If I am using the rc in channel 7 as an auto tune trigger, but not using the channel 7 output, is there a way to pass, say, channel rc 10 in out to channel 7 so that I can control channels within the current sbus out limitations?
      I guess I can use channel 7 as a pass through and one of the higher channels as an auto tune trigger. Not ideal but it will work.
    • This reply was deleted.
        heliroberto,
        This means that the EKF is unhappy (at least temporarily) probably because the compass + gyro or accelerometer + GPS data does not agree.  In your vehicle's case it's got a "-2" followed by a "-0" very early in the mission.  This means the error occurred but then cleared so I wouldn't worry to much.
