Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Randy,
I do have a two battery setup on the 650sport (for the video stuff), will try to power it from the second battery.
I think that i2c LED has the same i2c address as your compass.
Artem,
Is there a way I could change it (on a compass)?
Its a compass/gps M8N combo.
As far as I know nope.
But as Randy mentioned it could also be a power problem, however I think if it is the case, than it would also power down the whole 3.3v line on the FC board meaning that your gyros, acc and the onboard compass would be malfunctioning.. Also, as far as I know most of the m8n GPS/mag combos are powers through the 5v line of the GPS serial port,,,
You are right.
I have connected only the SDL/SCL/Ground wires from the compass to the I2C.
The power is coming from the GPS port.
Something of possible interest. Frame- Hoverthings Flip FPV w/ 2212 980kv Sunnysky's. I have been flying a 3s setup with 11x45 HQ MR props for a while now. Last night I switched over to a 4S setup with 9x43 HQ MR props. IMU1 is nearly identical with either setup but the big difference is in IMU2. With the 3S setup, IMU2 is sometimes very erratic. So far (only a few flights), the 4S setup has IMU2 in check. I still have some tuning to do, etc..., but just thought I'd toss this out here as something of possible interest.
3s
4s
To me the relation between the two looks more or less similar.
But what is interesting is that IMU2 is that much higher. On my setups it is higher as well but only a little. Most probably this is also related to a specific frequency.
The difference you see is due to the smaller props on 4S: they turn faster and thus the frequency is different (higher) than on your3S setup. This shows your anti vibration mount does not blocked lower frequencies as well as higher frequencies.
Thanks for your reply and explanation. I have the controller mounted using only a double layer of 1cm squares of 3M 4010 double-sided gel tape at each corner.. After a couple years of 3S, I'm really enjoying this new found world of 4S capabilities.
Developers -- My hat is off to all of you (or it would be if I wore a hat).You folks seem to be working 24/7 on the development/testing/analysis/fixes and forum. I don't know if this is how you make your living or just a labor of love but whatever it is, you are doing a great job of it. I, for one, really appreciate what you are doing. A big "thank you" to all.
