Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • I haven't looked at the log, but there is a bug in the UBX handling with dual GPS's in that it logs both datastreams in the same slots. This means that the UBX messages flip between the two GPS's making the output look weird. I discovered this yesterday and plan to fix as I am running with two GPS's at the moment and want to make some comparisons.
        • T3
          OK, thanks!
          Then these sawtooth pattern make sense.
          • T3
            ...not sense, but we know where they come from :-)
      • thanks for looking...no I have never had any motor/esc probs with this copter and I have had it since march......i have flown it several times since yesterdays incident (but on AC3.2.1) and not one single hiccup.....
        whats agcCnt for UBX1?  and GPS2 is an M8N while GPS1 is M7N...but why would it care if GPS2 had no fix as long as GPS1 was ok?
  • T3
    Hi all,
    this is OT, but since this feature was mentioned here a few times:
    Anyone playing with the new log bitmask feature in Mission Planner (1.3.30.2 beta) be careful (https://github.com/diydrones/MissionPlanner/issues/938). You might end up with the wrong bitmask value and loose data. (I now have some nice images but no GPS and CAM logs...).
    Best regards,
    Thorsten
  • Randy,
    could you please check if geofence arm check actually looks at the value of GPS_HDOP_GOOD value to establish if geofence is ready or if it uses some other hardcoded value? As it takes very long time to arm when geofence is activated and I usually get to 1.3 - 1.4 HDOP when it finally gives a signal that pre-arming check is completed.
    hdop good parameter i did set to a value of 251 to speed that up and without geofence is works fine and lets me to arm in position hold almost right away as I hook to 9-10 sats immediately. with geofence on I have to wait for 3-4 min minimum until I get to minimum of 11-12.
  • rc7 is ignoring the roi points in my auto mission. The points get deleted from the mission plan after a flight. How do I get roi working again?
      Arni,
      Thanks for the report.  It's best to include a log.
      Without a log, my guess is that it's a ground station issue because the Copter flight code never deletes mission commands.
      Make sure you're using DO_SET_ROI commands and not NAV_ROI commands (NAV_ROI commands should not even appear in the list of available commands unless the GCS is out of date).
      • Thanks Randy, sorry I forgot the log here it is log. I tried with MP stable and latest beta 1.3.30.2 without luck. Added the DO_SET_ROI command after first waypoint.
        2015-07-17 22-31-00.bin
