Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
http://diydrones.com/forum/topics/effects-of-frame-design-on-barome...
I've found that when in autotune, it will loose altitude rather quickly when bringing it back to its starting area. The trick is to bring it back slowly (and add some throttle if necessary to maintain altitude). I've also noticed that the closer it gets to finishing the autotune, the more it will maintain its altitude when bringing it back to the starting area.
Hello, I have the following problem.
I have successfully flown my hexacopter on 3.2.1. I now wanted to upgrade to 3.3 RC9 because FrSky Telemetry should work there with X-Receivers.
The upgrade went good, but I just can't get the accelerometer calibration done... I tried different laptops and even android to do it, but it always does a step over! For example, it shows "Place your autopilot leveled" I level the vehicle and press next. Then "place it on left side" is shown for half a second and immediately "place on right side" is shown, whithout me clicking okay?! I tried it over 30 times now and just can't get it done, which is pretty annoying :(
I am using latest beta MissionPlanner!
I had Mission Planner do the exact same thing. Restarted twice and now it works. Strange.
restarted your Windows twice? Well, this is so strange oO. I have already restarted my computer several times and Mission Planner maybe 40 times.. Also tried reinstalling everything.. also android doesn't work.. Well it works now with the dev firmware and I was told to be fine flashing back to 3.3 and keeping my values.
You don't click next its press any key to move between the positions.
I already tried with spacebar.. still the same. Also why doesn't it work via android then? its also just pressing on the screen.
I flashed some firmware from 25.07. (wanted to try RC8)
Mission Planner shows 3.4-dev.
Accel Calibration worked perfectly on this fw!
I tried 4 different more recent firmwares before with no success.
Can I flash 3.3 RC9 now and it will take those accell params?
I had a similar problem with APM Planner II several months ago with 3.2 and it did in fact turn out to be that GC software not the copter FW. Or.... Just for the heck of it try another usb cable perhaps it's defective.
Couldn't get your file. Wanted to look at motor voltage/current to have a scale idea.
Not saying this following should be but they work without mag problem:
- Small 500 mm quad 4S 8A battery props: 14x4.5. FC 100 mm above wiring/battery
- Medium 1 metre hexa 5S 16A battery props 17x5 T style. FC 170mm above wiring/battery
Had mix results with mag.
Magic trick: Self adhesive aluminium foil placed on the bottom frame.
No more mag issue whatsoever.
Hope this will help.
Henri
In the notes at the start of this discussion it has do not use 3.3 until you have flown the machine on 3.2.1. I haven't noticed that before until rc9 was put up. I've been assembling a new quad and was anticipating using 3.3 when it is ready. I've been loading the rc's as they become available and doing ground testing from there. Was there a particular reason to fly on 3.2.1 first? If so should I use EKF on 3.2.1 when EKF has seen much fine tuning through the 3.3 rc process?
