Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
        The throttle seems to stay at zero for this whole flight so perhaps this is the wrong log file?
        • was the only log file on it :( I'll try again a little later today.
  • Can somebody shed some light on what might be going on with my hex?
    This thing has flown for almost 2 years and has been an absolute joy to fly. But not any more.
    1st symptom: Throttle is like super sluggish. When I give it throttle it like takes its time to actually spool up and takes as much time to spool down. I've calibrated the ESCS a ton of time.
    2nd symptom: I can get it in the air but then all of a sudden it acts like it's in auto tune (2) it pitches forward for no reason, then pitches back for no reason and I have to fight like hell to keep it from crashing.
    I think the attached log is from the few seconds I had it in the air tonight so maybe someone can help me deduce just what is going on.
    I took the FC off my beater quad after having quite a few successful flights, then set all the pids back to default and nothing I change makes it act any different.
  • Here's my dilemma.
    I have a Pixhawk that continuously throws up BAD GYRO HEALTH.
    And even though my Tarot 650 is perfectly still, the HUD is jumping all over the place.
    Some times even goes upside down, etc.
    I've seen uTube vids of this problem since 2013.
    I'm sure this could be due to a faulty board.
    But never-the-less, the problem seems to be very common.
    Now here's the interesting thing.
    I installed firmware 3.1.5.
    And just like that everything is working perfectly.
    Then I tried v3.2.1 and the latest 3.3RC10.  With the exact same problem.
    Reading through the release notes, I see that the secondary gyros have been activated as of v3.2.
    Looking at my lives stats I can see that gx,gy,gz are relatively still, but gx2,gy2,gz2 are jumping all over the place.
    This is why I came to to the conclusion the board is faulty with the secondary gyros.
    My questions is...I can use the Pixhawk with v3.1.5, but I was to use the latest firmware.
    So how can I de-activate the secondary gyros, so that it behaves like v3.1.5.
    I'm sure a lot of people will find this to be a solution to boards that are out of warranty.
    • Maybe try INS_USE2 set to 0?
      I see now it can be set to a 3rd Gyro as well, maybe we can now use an off board gyro?
      • oh man...that easy......can't believe I missed it!..you are right, it did the trick.
        Funny I was looking for a setting like this, but in flipping through firmwares I missed it.
        v3.2.1 doesn't have it.
        But v3.3 does.
        thanks for the quick response.
  • As promised I finished a full round of auto tunes on a hawk lite starting with 3.1.5, then running 3.2.1, and finally 3.3-rc10 with full logs and video
    They can be downloaded Here with video (large @ 2.5Gigs) or Here with no vids @ 6 Megs They contain logs and pids from before and after the auto tunes.
    A quick summary is 3.1.5 was good, 3.2.1 sucked, 3.3-rc10 was good but to be honest 3.3-rc10 stock pids felt much better.
    Starting in the morning [the only time down here with little to no wind right now] I'll run the exact same runs on a second hawk lite on the exact same frame [my beater quad] and post them as a reply.
    http://www.sshcs.com/Files/AutoTunes.zip
    • Totally agree 3.1.5 had the best autotune right away.  Did you do 3.2.1 autotune with EKF enabled or disabled?
      • Whatever is default :(
  • Parachute testing on RC10.  Haven't tested the chutes since RC4 or5.  But Can't seem to get them to work consistently.  After arming and powering up, I'll lift the copter and tilt it which should release the parachute.  Sometimes it does.  Other times I get crash detected and no parachute release.  Consistently it's a 50% of chute release of crash detection, but never both.  I've attached a log with the Chute error and one with a crash error.  Also, when setting the min_chute alt at 0 they won't release manually.  MP just says chute landed.
    2015-08-30 15-16-54.bin
    2015-08-30 15-17-48.bin
    https://storage.ning.com/topology/rest/1.0/file/get/3702082819?profile=original
