Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • I use RTL and land once in a while and even land from a mission.  They work every time for me.  Landing detection has gotten way better than it use to be.
      The thing is that I land often in Stabilize mode because of GPS Doppler effect from trees and building near my landing area.  It is far safer to land in this mode than risk GPS drift causing the craft to veer off and hit something.
      If your in an open area it should be fine to land in Loiter/Position hold or use RTL.  Motors always spin down and stop.  Too often people fly in front of there house and get unexpected results.
      To get a good HDOP the satellites need to be very far apart from each other to get good contrasting angles which improves HDOP.  This means that the satellite on the horizon that is blocked as you land is going to change the HDOP and your position.
      • GPS is certainly important to consider for trying to land in Loiter/Pos Hold, but I believe the issue is quite evident for Alt Hold as well.
    • yes, I agree.  I've learnt to land in landing mode/loiter, then the second it's landed to switch to stabilize and drop the throttle, but as you say that's not a great solution.
      the devs have done quite a bit of work on the landing detector but then I think caused a few false positives where the craft then thinks it's landed (but hasn't) and drops the throttle so it then drops out of the sky.  for me, it's better to have a tipover and lose a prop or two than have it drop out of the sky - i make sure to land it well away from me or anyone else for this reason, half expecting a tipover.
      as I understand it, currently it 'feels' for the ground but doesn't really have any idea where it is, kind of like a blind man feeling for an obstacle.  and if it's too optimistic, it will sometimes 'feel' something that isn't actually there, if it's too pessimistic it won't 'feel' what is actually there.  as randy said in an earlier post, the real solution here is to use a range finder to actually know where the ground is - if we know from the rangefinder we're on on very near the ground then it's much easier to drop the power reliably, I guess.
      hopefully this is something that can worked on for 3.4.
      • I'm pretty sure that is impossible now as they added another check that will not allow it to decided it's landed if the throttle is above 1/3 or something along those lines. So if your flying it's obviously above that.
        • Part of the tilt over problem is that the FC has more authority over the motors than the pilot input. When the multi try's to reposition after landing the pilot can be countering the move with full stick inputs but the multi still tips over.
          A kill switch is an ok idea, but requires another pilot input just like flipping to stabilized mode. The goal should be to fix this problem through a way that protects novice pilots from having their multi tip over.
          I like having stabilization functioning even after I touch down. During windy landing or when landing on uneven terrain I want to see that the multi is stable on the ground before I bring the throttle to minimum.
          Could the GPS radius for position hold be loosened up when throttle is at minimum?
          Another approach might be limit the maximum tilt angle to 10* when throttle is at minimum so that the multi would not be able to lean far enough to tip over in the first place.
          • It should also be noted that a number of flight controllers actually "turn off" the integral portion of the PID during take off to prevent flipping in situations where the operator increases the throttle slowly.
          •   This "flip on landing due to a small lateral move" problem really looks a lot like an unbounded integral wind-up issue.  Preventing the error from accumulating to an unreasonable degree should do much to control this.
              Limiting a max tilt angle is also something that should be prioritized over position corrections in a landing type of flight mode mode.  I suspect that without first better limiting integral wind-up,  limiting max tilt angle won't actually be effective.
              It would seem that the ideal behavior would be as follows:  In a situation where a copter meets resistance while moving laterally, it should tilt in a controlled manner to a maximum angle and then hold that angle indefinitely.
              This may fall under the category of "easier said than done", but it seems like a reasonable goal.   Very likely the changes needed to effect this behavior would result in undesired effects in some flight modes, as such it might make sense for the changes to only be effective in landing types of flight modes modes.
  • I have been flying with rc10 since it came out and everything was fine till today.
    I was on my second battery of the night and after 5-6 minutes for some reason my Y6b suddenly rolled/yawed in place and then would straighten out again. This was in stab mode with simple mode on. This happened several time and then the copter seamed to loose power and started slowly decending. I was still able to apply roll and pitch but it ended up coming all the way down and flipping over when it hit the ground.
    After the crash I noticed that the GPS mast was a little bit loose and could easily twist 5-10 degrees. Not sure if this was caused by the crash or went loose during the flight.
    attached is the log from that flight.
    Any thoughts/insights would be greatly appreciated.
    • hmn log file didn't seam to attach so here it is via google drive
      https://drive.google.com/file/d/0B9lPaNf0CEySMGFLRy15WW00bzQ/view?u...
      37.BIN
        Yssaril,
        Thanks for testing.
        Looks like motor #4 (bottom back) is failing.  It shows the classic signs which is sudden separation of the desired-pitch vs actual-pitch (it suddenly pitches back which is consistent with a rear motor failure) and the output sent to the back motor goes to full (i.e. it's trying to get more power out of the motor but it's not).
