Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Hi All,
1st of all I would thank whole dev team for awesome work on 3.3.
2ndly,Today I have been doing some test flights with version rc10 and had a crash.
At the end of the flight my copter has suddenly bounced up in the air, I took throttle down and the copter started to fall like a stone. I tried to add throttle not to hit the ground but I crashed anyway.
Can someone please take a look at my logs and see if there is anything suspicious?
Also I seem to have issues with auto-tune (I did it on rc9) where after auto-tuning whole platform was wobbling in Pitch and Roll.
I had to decrease P and D for about 30% in order to have the platform more stable.
Still it doesn't fly as I would like it - maybe someone looking at the log could give me a hint what's wrong.
esamolocik,
Thanks for testing and sorry for taking a while to review your logs.
I can't help with the autotune but at the end of the log the vehicle was in Stabilize mode. You probably know but just in case, in stabilize mode the pilot has full control of the throttle. Essentially the pilot controls the vertical acceleration.
The CTUN's ThrIn and ThrOut look pretty consistent with the Altitude ("Alt") and climb rate ("CRt").
I think you pushed the battery too hard. You can see the requested throttle shoot up at the end, the current spike and the voltage fall off a cliff all at the same time. You aren't logging RCOUT so its hard to see what the motors are doing.
If this is 4S you should set the battery failsafe higher - say at 14v or more.
My $0.02
That's odd as this is the first time it happen with this battery.
I need to take a closer look at it.
Also, is there anything I can improve with my PIDs?
here is the log file:
2015-09-19 17-47-16.bin
I had a flight about a month ago on AC3.3 rc8 in which I had an EKF triggered failsafe as well as a later NO-RC Receiver failsafe. Up until this point (and immediately after changing modes) everything has been fine, and seemed fine at the time. I'm hoping someone can review the log and give me an idea what caused the EKF failsafe and how to prevent it in the future. I think it is compass related and not sure if there is an indication I need to re-calibrate the compass, or if it's something else entirely.
As to the RC Receiver signal I'm stumped. The RSSI was about 97 right before the failsafe then dropped to 0 for about 1/3 sec. the failsafe was triggered then it was back to 97.
The short clip below shows the various screenshots of the tlog replay with VIBE and EKF scopes open (love these by the way).
Attached are copies of the above video clip, and a copy of the tlog.
Here is a link to the BIN file for this flight on my Google Drive.
I haven't had any time to fly since this flight and want to upgrade to AC3.3 rc11 before my next flight, but I want to understand what's going on here first.
Nathaniel ~KD2DEY
2015-08-16 14-30-03.tlog
2015-08-06.wmv
Something is weird here. I used to get these a lot and they were indeed badly calibrated compass. But your's is different. At the time the failsafe triggers everything spikes - the MAG innovations, GPS innovations, Baro innovations, all the motors blip as well. I can't see an obvious cause, vibrations look good. I just wonder if it was some kind of mechanical knock that set everything off. There's also a sudden drop in voltage, both on the battery and FC - so I suppose brown-out is possible, but maybe these are just reflecting the sudden power surge when all the motors blip.
The other weird thing is the learned gyro offsets for Y (EKF1->GY) & Z (EKF1->GZ). They both get quite large and then suddenly reset to 0. There is also a weird blip in Y at the time of the failsafe.
Maybe just chalk it up to experience and install rc11 :)
Do you have the log for the RC failsafe? I've been having some of these which I've been blaming lemon for, followed by bluetooth - but today I went way out with bluetooth on and no issues, so I wonder if there is a software fault. Again this was with rc8 or so, rc11 now much better so I should try it.
Hey Andy,
The RC Reciver failsafe is in the same log. I don't know where it is in the BIN but its 3:44 into the flight on the tlog (79.79% of the file).
I think the X and Y vibes look pretty good but I think I can get the Z better if I remove some of the play in the motor bell housing on one or two of the motors.
I've done the Mag/Current Compasmot and a Compass Calibration (with the original setup but not since). Not only do I want to fix whatever is causing this, I want to understand what's happening. I suspect it's vibration related, but I don;t see the evidence of that.
When the EKF failsafe kicked in I switched modes from Loiter to something else and back again to stop the landing (from my viewpoint it looked like I was over trees). Immediately everything returned to normal. I have my Loiter speed set fairly high compared to the default, not sure if that has anything to do with it. I know some people say Loiter isn't a "Flight Mode" but it works for me and I like the convenience of just being able to stop and take a break to look around without having to switch modes when recording.
Nathaniel ~KD2DEY
Hi Nathaniel, I took another look at this. I see the RC error in the RC input, but I don't see the failsafe.
Anyway, take a look at GYR1/GY2->GyrX - I think this is your problem, the gyros don't agree with each other and eventually the EKF gives up, resets itself and this results in the twitch you get. Maybe the copter was moved while the gyros were calibrating? I would do another flight and check that the gyros agree with each other. If they don't maybe its an issue with the board?
Andy,
Thanks again for taking a look. Can you explain or even better post a screen capture of the GyrX comparison that looks like they disagree. I took a look and I admit I'm not really sure what I'm looking at, but it looks like they follow the same mean however one has greater amplitude in it's plot than the other. I just want to better understand what I'm seeing.
As far as moving while calibrating, I'm very careful about that, but anythings possible; perhaps a breeze.
I don't understand why the BIN file doesn't appear to show the No-RC Receiver with an RTL failsafe. The tlog clearly shows it and it definitely happened. The BIN file does show the low (968) throttle that triggered it on ch3 RCIN. That's strange.
I'm going to update to AC3.3 rc11 and take another flight as soon as the wind co-operates!
I've posted another BIN file here from another earlier flight for comparison. If you get an opportunity, could you take a look and see what you think about those gyro values?
Best Regards,
Nathaniel ~KD2DEY
