Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
        • try to do a good calibration, do not use auto accept.
          also, are you using compassmot?
          • Yes, I have to as its a 250 class quad and there is a lot of interference
            • what kind power module are you using, is it arsovtech one or 3dr or a chinese?
              the reason why I am asking is I remember reading about an issue with x2 in which on USB power only (no lipo connected to PM)  X2 was reading false current and AC applying compasmot offsets according to the current reading, but since those readings were "false" the offsets were too, thus EKF was not happy. Once again, I remember reading about it, but do not know where it was. I suggest a little test: disconnect current pin (only that pin of the 4 wire PM-X2 harness) and under USB power only (nothing connected to PM) check for the voltage on the current pin. If it reads anything other than 0, PM is leaking voltage through the BEC in reverse (I think it means it is missing a diode).
              • That was me on rcgroups :) So yes its an arsovtech one.
                So it gives bogus readings on USB power, but on battery power (which is what I am reporting here) the readings are normal. I checked the current when I landed and its the same as when I took off. So I'm not convinced this is a PDB issue, but it could be I suppose.
                • maybe it is not a PM, try unplugging current pin, but leave all others connected, see if there is any "current" detected by x2.
                  • Hi Artem,
                    Finally did some testing of this:
                    - With the PM connected only to battery (no FC) it reads 0.14v on the current pin.
                    - With the FC connected to the USB, the PM connected to the FC  but the current pin disconnected it reports 0v relative to the PM ground, but 0.4v relative to the ESC ground pin on the FC (I assume this ground is common in the FC?)
                    So I'm guessing that somehow when the battery is connected it makes the grounds align? Not sure I understand electrically what's going on.
                    Another weird thing if I disconnect the PM input and connect the battery the FC still powers up! Only if I disconnect the ESCs does it not power up, seems weird since they are RCTimer opt-ESC's and don't have a 5v wire.
                    All very confusing!
                  • But even if this is the case, why would I see the behaviour I am seeing? Its fine first time around, only the second with the same battery still connected is a problem.
  • Does APM Leak?
    Without fail if I leave my bird attached to a power supply for a couple of hours when I try to connect to MP via USB it wont connect. I wondered if there was a memory leak.
    Reset the PH and it's all good.
    Not the end of the world ( I wish we were getting several hours of flight time :) ) but it might be in the future.
    • Have a habit of leaving hawks plugged in USB and going to sleep than to work and coming back the next evening to a fully working hawk. I suggest you carefully examine your board for cold solder joints and sometimes no-solder joints :) start with the USB plug as it's rather easy do damage one.
      • Ditto with me. Generally the airframe stays on all the time. I have a paper clip nearby to do a reset occasionally when I am playing adding hardware or tinkering with setups.
        Wouldn't surprise me if it's a Windoze problem. I've had it completely forget config for the 3DR data link, usb drivers the lot.
        This is all on a desktop, My business 8 core 32gig ram PC running Win 7.
