Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
thanks - yeh that was just someone posting something without actually reading first. bad info posted among good :D
the quad did a cross axis roll, not flip. i found a video of what that looks like. but thanks for the info on the ch7 flip option.
Did another couple of 15 min flights this morning- but first I upgraded to 3.3 final release. no issues during flight, everything rather normal, 3mph winds. only error i had on screen (randomly) was "bad ahrs" - it just comes on randomly throughout flight. no more "horizon error x.x" so that's sort of just vanished, maybe with the final release?
my EKF params were all within normal, my vibe "Z" column was a bit higher than I'd like and at times it would jump to clipping area. what specifically is the Z column watching?
quad is a bit bouncy in poshold mode after running autotune. like when it is holding a fixed spot it is sort of bobbling at all four corners. granted I know it is compensating for slight winds, but before autotune it was much smoother / not as bobbly. control-wise, it seems good though.
MP still has the bug where the HUD does not refresh the sat count, and also the flight mode, in the white "user defined" text overlays on HUD. I just updated to latest version of MP. the "quick" tab screen updates correctly though so the bug is isolated to the HUD overlays. this was consistent with telemetry over usb as well as remote telem over 3DR
I think this is where it occurred
- 19 mins into flight and just switched to althold (not sure why poshold shows stacked on top)- the "Roll" event drops way off the chart quickly.
Things that I noticed: Your roll and des roll didn't track in that moment, idem Pitch, so I think that your controller didn't want to flip but, perhaps a mechanical failure did it, as James said, very fast switch modes, if you didn't do it check PWM mode values, and the third thing that I notice is that your vibs looks to high and some strange thing in clips but I'm not shure how to interpret them.
My 2 cents: check your motors/props (bearings, little shaft bolt, etc.)
As you discover the problem, you have to practice that pirouette, now you know that your copter can do it ;)
thanks Cala- I actually went over the entire mechanics yeterday, tightened all frame points, motor mounts, prop nuts, etc, with typical blue locktight. then i wait at least 12hrs for the locktight to dry.
this morning before flight i went over the mechanics again, all 100% ship shape, and then post flight, all still 100% ship shape. motors are new, balanced, lubed etc.
I have a good idea where my added vibration is coming from- the RCTimer dome is attached to a deck, the deck holds the FC under the dome (hey isn't that a TV show? lol). The deck is attached to the main frame via four rubber barrel mounts so it kind of floats. I think this lends itself to wind buffeting of the dome and it moving around independently of the frame with gusts. I'm going to revise how this assembly is attached and I'm pretty sure it will be a large improvement. when there is no wind gusts, there is not much of a vibe issue.
If you look at the length of the switching between modes, there is at least a minute or two between switching. I was testing drop in alt when going between poshold/althold/drift - and general drop in alt when rolling into the wind for sustained distances. I adjusted the throttle deadband for altitude hold modes and also my general throttle mid.
Obviously there may be unexpected results if recklessly flipping modes back and forth within a second or two. Let's be realistic here guys :D
You say you didn't switch to Pos Hold? How are your Pwm values? Isn't that the problem
no i only use one single switch for three flight modes (2, 4 and 6 according to pwm values on my channel 5 switch) so the switch is either high, low or middle and falls exactly on either 2,4 or 6 flight mode. no overlap or use of other switches. I do have ch7 set up for auto tune but that is well separate from ch5 flight modes.
dont switch so fast between modes.. make one decision ok i want this mode switch to it and stick with it for 10 seconds min.. then if you want to switch back go ahead but dont switch then switch to something else.. that might be your problem...
thanks but that's not the situation.
Congrats for the new Release 3.3 !!!
Is it possible to bring under two small changes i haven't seen so far ?
1. Throttle mid minimum value seems to remain stock on 300, could it be set to 200 ?
2. Could the Battery FS Alarm be reset by disarming the vehicle ? As it is now the Battery need to be disconnected.
