Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      Stephan,
      Really sorry for the crash.  I'm sad to say this looks like either a bug or missing sanity checks somewhere in the follow-me processing code.  We actually saw this once during beta testing of Copter-3.3 and although we couldn't find the exact cause we did add more checks and it didn't happen again (until now).  I will try and find other ways this could happen and come up with some more checks.
      Can you tell me which version of Tower are you using?
      EDIT: sorry, I see you've said you're using Tower version 3.2 which is the latest.
    • sorry about the crash, i am no expert but I took a look anyways and it looks like the throttle got cut, i took a pic of that, because right after that it came down. i dont see anythng wrong with pixhawk....I know i tried followme last week with Tower 3.2.0 and AC3.3 and it worked great for me.....
      https://storage.ning.com/topology/rest/1.0/file/get/3702599310?profile=original
  • This reply was deleted.
      I think it would be good to measure the battery voltage with an external volt meter to confirm the change in voltage isn't real.
      The board voltage is very likely changing when the USB is plugged in.  That should be accounted for in the Analog-To-Digital converter.  You're using a 3DR Pixhawk?
      Hi Joe,
      Could you add some photos of your test setup and some details on how you are doing your reference measurement.
      Thanks,
  • hi, is it possible to connect a brushless gimbal (not servo!) to my APM?
    thanks for any help.
    • answer is yes and no ! only Storm32 BGC supports the Pixhawk can be connected in that way! all other BGC must be connected to RC Rx directly.
        BTW, we also support the AlexMos gimbal using serial but we've never documented how to do it.  On the Pixhawk side it's very similar to the set-up for the SToRM32 but I'm personally unsure where to connect the serial lines on the gimbal controller which is why I haven't documented it.
        • Hi Randy, is there any progress on the Z1 Tiny2 gimbal to connect to AC?
      • Hi OG, that's not correct, pixhawk supports almost all gimbals:
         http://copter.ardupilot.com/wiki/common-cameras-and-gimbals/
        • Hay Fnoop! well that why I mentioned Yes and No !
          One channel that's can be used for tilt only ! not support at all ! Alexmos, Mrtenez and Tarot also have other channels ?  there are 3 channels 3 axis on a gimbal?
          Storm32 is supported fully! all other brush less gimbals are not supported as pas thru!
