Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • This afternoon another fligth but FPV now, pos hold, some less wind and no simple, all good.
    • This reply was deleted.
      • Yesss!, I acumulate and now I have to use all together ;) ....tomorrow rainy forecast :(
  • Hi! i just flashed the latest AC3.3, but now my 2axis alexmos gimbal does not work. on the previous build, I just set MNT_TYPE to servo. now it does not seem to work. can anyone assist me?
    • I don't know about that specifically but it seems like if you select RTL yourself and then see if it announces it on your TX that will be your answer right?   Or,,, perhaps I don't understand your question probably :]
      I'm having issues with my script with 3.3... it works but has some issues I noticed last night several of the data fields isn't correct or doesn't change. I think they are working on this over here http://diydrones.com/forum/topics/amp-to-frsky-x8r-sport-converter?...
        • When a failsafe is triggered it changes mode just like if you had manually changed it. So, yes, it will show up as RTL in your Taranis.
            • Yeah, I don't see why it wouldn't work.
              Yes, T1 is a temperature, but it doesn't matter, just put 6 there and it should work.
        • re- if RTL is transmitted as the new flight mode in the same manner
          You mean does ardupilot send the RTL verbal to frysky T1 the same as if you did RTL yourself?
          sorry just trying to clarify so somebody else can let you know. Or... I guess you could set a really safe high voltage fail safe and see what it does.
            • My point was is it  reported as RTL when it goes into RTL regardless of what set it to RTL. Yes.. not sure why it wouldn't.. but stranger things have happened.
  • Another try here:
    A terrible windy day, I take off in stab, then althld, pos hold, a short mission, land from the tablet mode, arm from the tablet- take off-abort and take off again from the Tablet mode, fly in pos hold simple mode, some RTLs, and all works pretty nice :O :D
    Impressive: the first time that I use the m8n, I live in the south cone far from first world so I haven't a lot espectations with this gps, It's fix 16-17 sats with cloudy day :O , I did a mark on the floor, take off-fly far and switch to RTL and the copter landed exact in the same place :O :O ; If It is repeteable, I'm going to make a mark in my club and explain Phantoms pilots why I'm the only crazy woman in the club that prefer a Diy dron with Pixhawk LOL. MANY THAAAAANKKKSSS!!!!!!
    • Nice!! Thanks for the report. It does seem better in the wind than 3.2 doesn't it?
