Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
          • Yeah I get that. Hitec is a really good company and I hope they match the competition.
    • HobbyKing's 'Taranis-killer' (ok, exaggerated, but it's HK) is on sale for 50% off right now - the Turnigy 9xr Pro.
      $50 instead of $100, for Black Friday.
      Includes speaker and voice alerts. Some people are hacking the speaker for more volume, and substituting their own audio files (see dedicated thread on RCGroups.com).
      I've ordered one. It's HobbyKing, so wish me luck.
      (hope I'm not violating TOS by mentioning this)
      George
      • Haha that's a joke right?, that radio in the video looks like a Spectrum DX something or Airtronics not a cheap Hobby King transmitter.
  • Did a quick test flight today with my Hexa Copter version 3.3.1. Rebuild to reduce vibrations. Did all calibrations, but now i get compass variations during flight.
    Can someone please advice ?
    Thanks...
    2015-11-26 10-55-23.bin
    • Hi Randy,
      Probably busy after holidays and upcoming release.
      Can you please take a look at my issue.
      Thanks..
  • Randy
    Is this the file I need to direct APM P2 to install in my quad frame / pixhawk to test boat mode? ArduCopter-v2-2.px4
      Richard,
      Boat mode isn't included in Copter-3.3.2.  If you're feeling brave you can load up "master" though you can go to MP's  Install Firmware page and press "Ctrl-Q" to get V3.4-dev.  Many of the devs fly master but please remember it is broken from time to time.
  • Yesterday, my copter failed during a full throttle raise.
    I don't know yet why it came down, but I was in stabilize mode and it started failing during that mode, so GPS and MAG can't be the cause.
    I tried to hold it by switching to loiter, but it didn't change anything.
    Because of the rotation and the autopilot logging all the time, I thought it must be motor or esc failure. But the motors and escs are working fine even after the almost 60 meters falldown.
    It fell into the field and one motor holder broke.
    Here is a video, a picture (after the crash and with the fixed motor mounting) and the logs. I hope you can help me find the cause.
    https://youtu.be/fbg2rrQhQwU
    Here are the specs:
    Quadrocopter 580mm
    RCTimer 5010 530kv
    Afro OPTO 30A ESCs
    6s 5Ah 30C battery
    Pixhawk flight controller (AUAV-X2)
    Arducopter 3.3.1
    2015-11-21 14-35-55.log
    • I setup a sync issue test bench.
      I measured the exact signals with my scope and built a small tool to output the exact values the flightcontroller does with an fpga module.
      here is a video. in the top chart, you can see the pwm value, in the bottom chart, you can see the current.
      Looks all fine until now :(
      YouTube
