Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
I made larger flights with new release with FPV and notice that some times, when I was in pos hold and pitch to start the fpv fligth, pitch react more violent than usual but them the fligth was normal, I remove the gimbal and the issue stays there but not always, that's the strange, I download the log and notice that pitch didn't track desired one
Any idea what happens?
Log: https://www.dropbox.com/s/u9k7nryhahz3k65/2015-11-30%2016-22-04.bin...
Hi Randy,
Can you please look at my log, and posted compass issue reported few days ago?
Link to the post
Thanks...
Dave,
So Copter-3.3 only ever uses one compass and it won't fall back to the internal one if the main one fails (this may change in Copter-3.4 if the EKF can determine that the internal compass is ok).
In this case, the EKF's heading estimate became off by 90 degrees because it "reset" the heading when the compass recovered. It sounds like Paul will add some extra protection before it does the reset.
Because the EKF's heading was off, the vehicle flew off in the wrong direction. So for example, if the GPS says it's too far east then the vehicle tries to fly west. But with a bad heading it might fly south. After a few seconds it figures out that it's flying in the wrong direction but it can fly rather far and fast in that time.
I'd just like to clarify that you only have 1 external GPS attached right? Trying to attach two external GPSs won't work and could explain the compass health failures (and possibly the bad data).
Randy, could you please clarify if this flight would have been recoverable under normal control if the mode was switched back to stabilise?
FnoopDogg, yes, switching back to AltHold or Stabilize would have allowed the pilot to recover.
Had a strange GPS experience with 3.3.2-rc2.
Basically you can see that late into the flight the num sats drops to 0 and the HDOP goes to 99 and the copter hits RTL. However, nothing else is awry - including in the UBX messages. The GPS appears healthy and the signal quality appears healthy. Is this just a glitch or is something else going on here? The thing that is puzzling is that in the GPS glitch in the first part of the flight all of these things move in tandem, but for the second its only HDOP and numsats.
114.BIN
@Randy
Great job. installed today, just waiting for the weather to clear. Thank you for your efforts to make this system great,
Copter-3.3.2 has just been released as the official version. It's exactly the same (except the name) as Copter-3.3.2-rc2. Changes from 3.3.1:
1) Bug fix for desired climb rate initialisation that could lead to drop when entering AltHold, Loiter, PosHold
2) Fix to hard landings when WPNAV_SPEED_DN set high in RTL, Auto (resolved by using non-feedforward alt hold)
3) Reduce Bad AHRS by filtering innovations
4) Allow arming without GPS if using Optical Flow
5) Smoother throttle output in Guided mode's velocity control (z-axis now 400hz)
Thanks again to the beta testers on this thread for helping run it’s through its paces over the past few weeks!
Hi Leonard/Randy or anyone else, would love to have u look into this thread I opened few days ago.... Worried about flying again until I hear more from others.... There is also another user (Oliver) reporting a very similar incident now, it looks like we both sent a land command via tower which ended badly.
My copter had been flying flawlessly on 3.3.1 since it came out and all the sudden I have this bad crash on a landing sequence at very low altitude that damaged copter but also my car, but more worried it could been a person! Anyways enough drama, is just shattered confidence, we all know the current risks with autonomous flying, it ain't perfect, but hopeful we can make it as safe as possible. Many thanks for any help you could provide.
http://diydrones.com/forum/topics/another-crash-on-auto-land-mad-hi...
57
58
59
60
61
of 449 Next
