Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • Hi everyone,
    I was enjoying 3.3.2 but suddenly had crash  :( . I think one of the motors/prop/esc just stopped at ~55m and then just saw it falling
    Could you please help me figure out what happened ?
    Log here: https://www.dropbox.com/sh/033wkud5adiw7b9/AABEjRVYZaQEs6d8-mLwrSyN...
    2015-12-25 16-56-49.bin
    Dropbox - Error
    Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
    • Anyone kind to take a look please ?
      I cant really figure out what happened. It was fine before 3.3.2...
      • it looks a mechanical failure in motor 3, check it
        3702732112?profile=original3702732184?profile=original
        • Thanks for taking a look Cala.
          It also could be #4 right ? and 3 tries to compensate ?
          It is for sure the motor or could be the ESC ?
          coincidence or not the ESC #3 got pretty damaged upon hitting a wall (some capacitors and a few other components were gone), it could also be the case that it was this one that caused the fall and coincidentally the one that hit the wall, right ?
          I've bench test all the motors / and the three esc's remaining and everything works. 55m fall and not even a single propeller broken (damn APC propellers are made of steel ahah)
          • For me motor 3 is the problem, I'm not an expert but if I'm incorrect anyone else shure correct me watching the graphs. esc can be the problem too but a pitty that you can't test it. If you can't find nothing, repair it, test near the floor and then read log if you notice any ERR message, check connections and wires too, looking for any little damage.
  • hey there, I have a 250 sized quad running AC 3.3.2 on a PX4mini board by airbot, there were couple of compass related issues which I think I've sorted out, however when I attempt to take off copter starts spinning around itself very fast (keeping horizon though, kudos devs!) I've tried to determine what's the issue is but as far as I see from the logs there are no errors and RCin4 corresponds to actual stick movements. Can someone take a look at the log below to help identify the issue?
    p.s. log is from AC3.3.4dev but the quad behaves the same way on AC 3.3.2
    2015-12-28 22-47-36.bin
    https://storage.ning.com/topology/rest/1.0/file/get/3702153064?profile=original
  • Finally the rain and wind stopped! Did some flying with 3.3.2 and saw some weird behaviour. I occasionally get these huge spikes in ErrRP, ErrYaw and EKF SV & SP. Haven't seen these before that I recall. A couple of flights show these the rest do not. The flying conditions were calm and the copter behaved well in flight, but these spikes seem bad. I can't find any correlation with GPS glitches, high vibes, mag interference or any of the usual suspects.
    [Note to Leonard, I also tried some 5045BN's for the first time and needed even greater divergence between P&I on both Roll and Pitch for stable flight. I've pretty much given up on autotune for this copter at this point. The attached log is for 5030's however.]
    124.BIN
  • I think this is the correct one.
    Sorry if in the previous post I had attached the wrong one.
    2015-12-29 10-17-22.bin
    • Hello Andrea,
      I had a quick look at your log and it seems that you have a problem with your center of gravity, you have your rear motor pushing harder thant the front one. Check if your copter is balance, and then verify that all your props are in the same alignment.3702609766?profile=original
      I made tests with bad motor mounts alignement and I had a CW/CCW bias that ended by yaw drift with throttle change and a small loss of stability during heavy yaw command. Here are my motors outputs before/after proper alignment to get all props in the exact same plan:
      3702609805?profile=originalOf course, after alignment I had no more yaw strange behaviour. I hope this may help you to fix your copter.
