Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • I have tried to use Lightware SF10 serial.
    Followed the instructions on the ArduCopter page.
    No response on sonarrange.
    Is it fully tested with 3.3.2?
    Raviv
    • hi bro, what's Lightware ? using for ?
      Raviv,
      Are you using the I2C interface or one of the other options (analog, serial)?
      If it's I2C then that's only available with Copter-3.3.3 (which is out now).
      • Hi Randy,
        Thanks for the reply!
        I used the serial port.
        • SERIAL4_PROTOCOL=9
        • SERIAL4_BAUD=19200
        • RNGFND_TYPE=8 (LightWareSerial)
        • RNGFND_SCALING=1
        • RNGFND_MIN_CM=5
        • RNGFND_MAX_CM=2500
        • RNGFND_GNDCLEAR = 15
        Checked the Lightware with the analog and with a pc and works.
        Just wanted to make sure its fully tested and if anyone else tried it yet.
        Raviv
  • Just tested IRIS+ with new 3.3.3 software. Tried only on Althold flight mode for about 6 minutes. Probably its placebo effect, but feels like brand new LOL
    We’ve release Copter-3.3.3 today which is just a renamed version of Copter-3.3.3-rc2.  To recap it has these over 3.3.2 (Release Notes):
    1) bug fix to Guided mode's velocity controller to run at 400hz
    2) bug fix to MAVLink routing to allow camera messages to reach MAVLink enabled cameras and gimbals (including SToRM32)
    3) Restrict mode changes in helicopter when rotor is not at speed
    4) add ATC_ANGLE_BOOST param to allow disabling angle boost for all flight modes
    5) add LightWare I2C range finder support
    Separately it looks like the Pixracer issues are mostly resolved and we plan to push out a special Copter-3.3.4-pixracer tomorrow.
    Thanks all for your testing!
    • Hi Randy
      I had a crash today.After the first flight (about 17min) I decided  to had another flight. The copter was in hover and just increased the throtle (In pos.hold mode about 3-4 meters from ground) with out any other input  the copter leaned right and it fell to the ground like a rock.
      Quadcopter
      pixhwak with copter v.3.3.3
      2016-03-06 17-14-59.bin
    • Hi Randy
      and thank you for your grate work.
      I installed the version 3.3.3 in pixhwak. Today i had a test flight.The GPS locked 11 sat bat after armed and the copter was in the air I lost the gps and the copter return to  failsafe land. I am trying  3 times with the same results.
      Thank you in advance.
      pixhwak 3dr
      telemetry 3dr 433mhz
      battery 16000mah.
      gps m8n ublox
      2016-02-28 14-38-09.log
      https://storage.ning.com/topology/rest/1.0/file/get/3702620920?profile=original
      • It is clear that you have bad GPS reception. It may be caused by GPS receiver low quality, bad cables or GPS jamming if it is close to a transmitter.
        Do you have the GPS on long pole above the radios and the FPV transmitter?
