Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Hi VP Kuisma, and all
I'd did it, and same as you.
That i can see by trying the Copter 3.3rc4,serial 4: 57k protocol 1,(full parameter tree)
it's that with the Storm32V0.76x, i have in TM MP two quad, on one the right place and one 0°N, 0°W!?
and when the teensy or Tower had the mavlink flow, mode change continuously from stab to rtl (or unknow for Tower) but not by TM and MP?!
Maybe due to the new bridge for th Strom32 by the MP telemetry, or something like that...
i'm waiting for the Betacopter V3.3Rc4 by OlliW, wait and see...
I read that still only telem 2 is possible with storm32.
But I have a similar question: I want to switch OSD and teensy (S-Port) to serial4. But what are the corresponding SR parameters for Serial4? SR3?. Its a litle bit confusing.
Cheers Gregor
Gregor,
I'll make a wiki page to describe how to assign the serial ports but basically it involves modifying the SERIALX_PROTOCOL parameters where X is a number from 1 ~4 so no need to modify the SRX_ parameters I think.
Hi, I'm currently trying to get 3.3b working on PX4+IO.
Currently I've gathered a couple of questions:
/!\ IMPORTANT /!\ Dear devs who are in contact with Pixhawk webmasters, please add note here (http://copter.ardupilot.com/wiki/common-load-firmware-px4/#load_fir...) that TO FLASH PX4IO YOU HAVE TO UNPLUG PX4FLOW!!!11oneone. I upgraded PX4IO many times and still sometimes you just follow the instruction which sometimes results misunderstandings.
Thanks in advance.
Ok. digging process on MK-BL ESCs goes on.
For now there is new information:
1. To enable autorun of mkblctrl driver on arduCopter you have to create file /etc/APM/mkblctrl with correct motor numbering.
Does anybody know what "correct motor numbering" means in terms of syntax or usage example?
2. Found this config here. It moves me one tiny step forward on understanding how does it work inside.
I guess I need dev's help after all. I found 'mkblctrl' in code here and I found mkblctrl driver, but I can't really figure out at which moment driver loads config from file and what options are needed.
Marco,
1. I've heard of some developers experimenting with the I2C ESCs but I've never used them and I don't think they're supported in ardupilot. They are supported in the px4 stack which means we could enable the pass through but I've never done that. The plan is more to move to UAVCAN bus ESCs rather than I2C ESCs in case that matters.
2. PX4Flow wiki instructions are here. I see in the MP's status screen there are some new "opt_m_x", "opt_x" values that have appeared. I'll bet those update when the sensor is working.
3. It's possible to bring back the CLI but it's a clunky interface and we're trying to make everything done through the ground stations with MAVLink if possible. Any particular features you're missing?
4. It's probably the RC is not calibrated properly. If you set the LOG_BITMASK to All+Disarmed it'll log while disarmed and we can see if the RC is working correctly. The MP (and other GCSs) also allow arming so you could try pushing one of their arming buttons and watch for the failure message on the HUD.
5. pixhawk leds and sounds are on the wiki. We're making progress on updating the wiki ahead of AC3.3 but it's not completely up to date yet - the leds and sounds have not been updated yet although most haven't changed.
There shouldn't be any need to update the PX4 IO board separately anymore. That's done automatically when the main FMU flight code is uploaded. Sorry, we need to zap that last bit on that page.
Thanks, hope this helps some.
Hi Randy,
I have been flying mkblctrl quite happily on a hexa with pixhawk and 3.2. Now I have upgraded to 3.3 and the motors dont start anymore. I think a lot of people at least here in Germany have mkblctrl escs.
Its sad that I have to downgrade now because a good and nice working thing is discontinued. I think one should be able to rely on downward compability when an update comes out.
By the way I have your Solo and I think you have done a great job there. I am more than pleased.
Regards
Derek
I agree that UAVCAN is better, but my ESCs have only i2c and it would be too generous of me to throw em off.
Kinda intense topic...
