Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • Cool feature, good to know.
      • The Lost copter alarm works really well. Tested is a couple of days ago and it's nice to be able to let it beeb once or continue to beep as long as the stick is held down / right
        1:10 in the video
  • Has anyone else tried to use serial 4/5 with storm32? I have got it working only in tele2 port. How ports and configurations match? Are ser1-4 configurations tele1,tele2,gps,ser45?
    • Hi VP Kuisma, and all
      I'd did it, and same as you.
      That i can see by trying the Copter 3.3rc4,serial 4: 57k protocol 1,(full parameter tree)
      it's that with the Storm32V0.76x, i have in TM MP two quad, on one the right place and one 0°N, 0°W!?
      and when the teensy or Tower had the mavlink flow, mode change continuously from stab to rtl (or unknow for Tower) but not by TM and MP?!
      Maybe due to the new bridge for th Strom32 by the MP telemetry, or something like that...
      i'm waiting for the Betacopter V3.3Rc4 by OlliW, wait and see...
    • I read that still only telem 2 is possible with storm32.
      But I have a similar question: I want to switch OSD and teensy (S-Port) to serial4. But what are the corresponding SR parameters for Serial4? SR3?. Its a litle bit confusing.
      Cheers Gregor
        Gregor,
        I'll make a wiki page to describe how to assign the serial ports but basically it involves modifying the SERIALX_PROTOCOL parameters where X is a number from 1 ~4 so no need to modify the SRX_ parameters I think.
  • Hi, I'm currently trying to get 3.3b working on PX4+IO.
    Currently I've gathered a couple of questions:
    1. How can I understand that my i2c ESCs are even detected in system? It's mkbl esc v1.1.
    2. How can I verify, that my PX4FLOW module is up and running? Do I need to build additional modules to get it working?
    3. As soon as 3.3 dropped support for APM boards, maybe it is possible to bring back console? I think in case of PX4/Pixhawk lack of resources is not that awful.
    4. Could not ARM my PX4 board. Neither with "rudder right", nor with "Press PX4IO safety button, wait till it gets solid, rudder right". It just won't arm. No preflight alarms generated.
    5. Is there a place where I can get "up to date" meanings of LED lights and Buzzer sounds, besides "in code"? Sometimes I feel like shaman trying to figure out what's going on.
    /!\ IMPORTANT /!\ Dear devs who are in contact with Pixhawk webmasters, please add note here (http://copter.ardupilot.com/wiki/common-load-firmware-px4/#load_fir...) that TO FLASH PX4IO YOU HAVE TO UNPLUG PX4FLOW!!!11oneone. I upgraded PX4IO many times and still sometimes you just follow the instruction which sometimes results misunderstandings.
    Thanks in advance.
    • Ok. digging process on MK-BL ESCs goes on.
      For now there is new information:
      1. To enable autorun of mkblctrl driver on arduCopter you have to create file /etc/APM/mkblctrl with correct motor numbering.
      Does anybody know what "correct motor numbering" means in terms of syntax or usage example?
      2. Found this config here. It moves me one tiny step forward on understanding how does it work inside.
      • I guess I need dev's help after all. I found 'mkblctrl' in code here and I found mkblctrl driver, but I can't really figure out at which moment driver loads config from file and what options are needed.
      Marco,
      1. I've heard of some developers experimenting with the I2C ESCs but I've never used them and I don't think they're supported in ardupilot.  They are supported in the px4 stack which means we could enable the pass through but I've never done that.  The plan is more to move to UAVCAN bus ESCs rather than I2C ESCs in case that matters.
      2. PX4Flow wiki instructions are here.  I see in the MP's status screen there are some new "opt_m_x", "opt_x" values that have appeared.  I'll bet those update when the sensor is working.
      3. It's possible to bring back the CLI but it's a clunky interface and we're trying to make everything done through the ground stations with MAVLink if possible.  Any particular features you're missing?
      4. It's probably the RC is not calibrated properly.  If you set the LOG_BITMASK to All+Disarmed it'll log while disarmed and we can see if the RC is working correctly.  The MP (and other GCSs) also allow arming so you could try pushing one of their arming buttons and watch for the failure message on the HUD.
      5. pixhawk leds and sounds are on the wiki.  We're making progress on updating the wiki ahead of AC3.3 but it's not completely up to date yet - the leds and sounds have not been updated yet although most haven't changed.
      There shouldn't be any need to update the PX4 IO board separately anymore.  That's done automatically when the main FMU flight code is uploaded.  Sorry, we need to zap that last bit on that page.
      Thanks, hope this helps some.
DIY Robocars via Twitter
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
yesterday
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Saturday
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Thursday
@gclue_akira CC @NVIDIAEmbedded
Nov 23
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9
RT @JoeSpeeds: Sat Nov 6 Virtual DonkeyCar (and other cars, too) Race. So bring any car? @diyrobocars @IndyAChallenge https://t.co/nZQTff5…
Oct 31
RT @JoeSpeeds: @chr1sa awesomely scary to see in person as our $1M robot almost clipped the walls as it spun at 140mph. But it was also awe…
Oct 29
RT @chr1sa: Hey, @a1k0n's amazing "localize by the ceiling lights" @diyrobocars made @hackaday! It's consistently been the fastest in our…
Oct 25
RT @IMS: It’s only fitting that @BostonDynamics Spot is waving the green flag for today’s @IndyAChallenge! Watch LIVE 👉 https://t.co/NtKnO…
Oct 23
RT @IndyAChallenge: Congratulations to @TU_Muenchen the winners of the historic @IndyAChallenge and $1M. The first autonomous racecar comp…
Oct 23
RT @JoeSpeeds: 🏎@TU_Muenchen #ROS 2 @EclipseCyclone #DDS #Zenoh 137mph. Saturday 10am EDT @IndyAChallenge @Twitch http://indyautonomouschallenge.com/stream
Oct 23
RT @DAVGtech: Another incident: https://t.co/G1pTxQug6B
Oct 23
