Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • This reply was deleted.
      Aleksey,
      It's more likely a display issue in the MP.  By the way, I strongly recommend using only the current based compassmot.  The throttle method is not very accurate and I was thinking of removing it completely.
          Hi Aleksey,
          There is a difference between Alt_Hold and Autotune flight modes in the way it behaves.
          Randy is fixing this now and we hope this should fix your problem.
          Thanks for your input!!!
          Hi Aleksey,
          We will check to make sure that the copter will disarm in autotune if autotune has not finished.
          I am the person responsible for autotune and have done an amazing amount of autotunes testing it. Autotune defiantly disarms once it has finished. However, I am not sure if it disarms when it has not finished.
          If you find the results of autotune have not worked well for you, can you please provide a log of the autotune and a log of the test flight.
          Thanks for your feedback and input!!
            • Vitashchi SD card i kachay s neyo....
                • Sorry bro, forgot another helpful thing - using a different USB cable and/or twisting the pixhawk usb/led adapter wires separately from each other i.e. usb data+vcc+gnd together and i2c data+vcc+gnd  in a different batch.
  • Hello,
    I've tried Autotune with my hexacopter running 3.3.RC3 and it all went well. Now I tried RC5 and suddenly autotune did not finish all axes, just roll and pitch and did not save the values anyway after switched off. Futhermore I'm getting warning "Error compass variance" any time I run more then 10% of throttle. I've recalibrated compass on Pixhawk and I know I have high offsets for internal compass. But I use Zubax GPS with own compass and this one is working fine, low offsets only. So I wonder why I get this warning..
    Thanks.
      Hi Michal,
      How long it takes to complete autotune may vary depending on a number of factors. You can do 1 or 2 axis at a time by setting the autotune bitmask, AUTOTUNE_AXES.
      Sorry I can't help you with the variance issue.
      • Well I've tried another test flight today and the result is even worse. I attempted to try Autotrim feature invoked from the flight start but I could not get off the ground even when throttle was 100% ! Then suddenly copter was able to take off at 60% as usually but after 1 minute of flight time it crashed to the ground. I'm really scared to fly with this copter now. Please is it possible to download RC3 firmware ? I could not find it..
        I'm attaching my logs from this flight.
        5.BIN
        2015-06-08 16-39-22.tlog
          Hi Michal,
          It isn't often I can give good news in a situation like this :)
          Initially I though, oh, this copter is seriously messed up, I wouldn't want to fly that again either.
          However, all that is happening is the copter has been moved after arming and is trying to rotate back to where it should be as it takes off. Because this requires throttle differences and you are so under powered. The average throttle is no longer able to lift you off the ground.
          If you see this, just disarm and rearm (you should be able to bring your throttle all the way down in stabilize). Then you should be fine.
          You are seriously overloaded for your power train setup. This is what is causing your thrust problems.
