Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • You can autotune axis by axis, check http://copter.ardupilot.com/wiki/autotune/ (search for AUTOTUNE_BITMASK ).
      My 470 sized quad took about 12minutes for a full run, total time depends on the frame and conditions.
      • My tarot 650 took 12 mins too (for the whole lot)...
        • my new tarot 690 build took 14min for first autotune and 11 min for second.
          in 3.2 longest autotune time was 7 min, may be.
          • Yes I can confirm that, mine 690S tooks also +/- 7min to complete the AutoTune with v3.2
            Like Erkki already have say you can use AUTOTUNE_BITMASK and do each axis separatly.
  • Randy or leonardt, I just had an interesting flight on 3.3rc5 it is a fairly short flight which ended up in crash w/o much damage.
    basically after a take off, my tried and true (running rc5 for several weeks now) copter started acting strangely and at the end of the 3rd minute it started dropping left arm RCout2 rather smoothly it was not an abrupt stop like a mechanical failure but I think lasted several seconds to me.
    After going through the logs I am failing to understand why AC commanded minimum to RCout2 while the copter was continuing to roll left?
    Thank you!
    2015-06-24 20-08-31 8.bin
      Hi Artem,
      I must be missing something because I can't see what you are talking about here.
      Could you put up a screen shot showing us what you are referring to?
      • Sorry, I guess, a bit much stress and I was looking on the wrong log, totally my mistake. In the correct log AC does what it should, but ESC/motor doesn't react as they should. My bad, this looks like a hardware failure. Looking in the log it does look as everything happened rather fast :), but to my perception the fall lasted several seconds, while IRL it happened in less than in a second..... I guess stress, the copter had at that time gimbal and a camera. My bad, again. If anyone interested here is the log (should be a correct one this time)
        2015-06-24 19-36-11.bin
          Hi Arterm,
          It looks like you are flying a tri and the front left motor is having trouble. You can see the copter is taking that motor (motor 2) to maximum and the copter is leaning forward and left (towards motor 2). This is further backed up by the rate logs.
          So as far as I can see everything is doing what we expect from a motor/esc problem on motor 2.
          I am glad the damage wasn't too bad!!!
          • Oh yes, leonardt, I've actually figured out that I was looking on the wrong log when wrote the first post, again, my bad.
  • I have a quick question, probably simple.
    I took my Iris out last evening and did an AutoTune, and it's flying really well. For about 1 minute after I launch, I'm getting the red/yellow flashing LED. It seems to fly fine during this period, with nothing unpredictable happening. If I land, it shows I have a solid GPS lock. So I'm curious about what that means.
    Thanks,
    Kelly
