Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • also, if it helps anything - here is a parameters file.
        7_23_aftertune.param
        https://storage.ning.com/topology/rest/1.0/file/get/3702710795?profile=original
      • HI,
        here is the shortest log with this issue, it occurs 3/4 into the circle mode flight, I definitely saw it on the MP screen.
        https://www.dropbox.com/s/8ivq9lsyyow5vd4/13.BIN?dl=0
        Not sure where in the log itself this message can be seen but it has happened, and this flight was done right after I recalibrated compasses.
        Dropbox - Error
        Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
      • I see this on both my vehicles as i have 2 compasses on both. I did motor compass interference calibration but not sure if it helped anything.
        I will try to post a log tomorrow. I saw this message today repeatedly after getting new compass calibration done, during circle mode at specific position only MP would flash this message. So i have suspected exactly same issue you just spoke about.
        Also, is there a list or xls of all messages with their codes? My taranis has voice files, i think, for messages with code id up to 122 or so, and i noticed some messages are not in the list now, like geofence, ekf, and this compass variance.
  • This reply was deleted.
      Julien,
      Thanks for giving it a try.  Could you set the LOG_BITMASK so that it's logged while disarmed and then attach a dataflash log?
    • I just flashed one of my multi rotors with 3.3r7 and I have no bad behaviors..  I previously had instability in the Z axis, In stable mode, I have to work the stick to maintain altitude, and in alt hold, it was either rising or descending until i overrode with the stick.
      Now with r7  it seems solid both in stab, and in alt hold.  I am not getting pre-arm messages or any kind of EKF or variance warnings either.
      I don't get good gps lock in my back yard so I wasn't able to try any GPS modes.  (High voltage power lines very nearby  seem to mess with GPS, not sure why)
      Description of my multi rotor:
      This multirotor is a quad F-750 with 6s and low KV pancake motors, using an early Pixhawk. I use a 433 immersion  EZUHF receiver with Taranis and a 1.258 Video link (400mw), 3DR radios, Tarot 2D, GoPro hero3 black.  Also i use a minim OSD for pilot feedback on conditions.
      on the ground station I use a DIY repeater to turn 1.258 into 5.8 for video to my fat sharks and 7 inch monitor with built in receiver and DVR.  I use Mission Planner and feel blessed for all the work being done to make all this stuff work.  It is being done by individuals for no monitory gain..
      To the Dev's. Thanks and keep up the great work!
        Richard,
        Good news!  My guess is that the altitude hold performance is improved because of the increased accelerometer range and improved resistance to vibration.  If you graph the dataflash's VIBE messages x,y,z values you'll be able to see more objectively how bad the vibration levels are.  Also if the clip0 or clip1 values are non-zero then there's still some bad vibes happening.
  • First, Sorry for the lengthy post :/
    Using 3.3 RC-7 I am getting some strange/unexpected post auto tune behavior and values:
    Using 3.2 auto tune: Values for pitch, roll, Yaw
    Stab Roll: 14.0      Stab Pitch: 14.0     Stab Yaw 10.0
    Term                Pitch     Roll        Yaw
    KP                     0.297    0.297    0.250
    KI                      0.297    0.297    0.010
    KD                    .004       0.004    0.0
    Using 3.3 RC-7 all of the values are within the defined maximum range with the exception of Rate Yaw as shown below.
    Using 3.3 auto tune: Values for pitch, Roll, Yaw
    Stab Roll: 5.4      Stab Pitch: 5.7 Stab Yaw 4.9
    Term                Pitch     Roll        Yaw
    KP                     0.107    0.110    0.745
    KI                      0.107    0.110    0.0745
    KD                    .0047     0.0051  0.0
    -  The Quad flies fairly well on both however there is a noticeable slow, but repetitive oscillation about the pitch and roll axis using 3.3. I Suspect the “I” term or Stab roll / Pitch may be to blame here?
    - Using 3.2 there is an oscillation about the yaw axis ~3-5 degree’s.  But pitch and roll remain locked on.
    - I have tried using 3.2 Values on 3.3 but the behavior remains the same.
    - I have tried increasing the Rate P and I terms using 3.3 for roll and pitch however the oscillations get worse and eventually the multirotor develops a decent rate of drift, usually forward and right, but sometimes to the left.
    -  In the log file there is usually an EKF error at the start however I was expecting that due to the metal roof in vicinity of my testing area causing a weak GPS Signal at takeoff (The error leaves once clear view of sky is obtained).
    -  I do not suspect that this is a vibration issue since the log files are reporting X and Y Vibrations of about +/- .1 units in a stabilized hover and +/- .4 units while maneuvering. Z Vibrations follow a similar pattern.
    -  Of note my multirotor has a COG slightly above the Pixhawk control board due to gimbal placement.
    My questions are:
    -  Should I be concerned about the High Yaw KP value post auto tune? It is the only value well above limits as referenced from the parameters list. Lowering the Yaw Kp Value seems to reduce yaw stability significantly to the point where a crash would be inevitable.
    -  I am not sure if the oscillations are visible in the log file looking at Roll Vs DesRoll or Pitch Vs DesPitch. Roll/Pitch does not match DesRoll/Pitch perfectly while stable but seems to track well while maneuvering. The oscillations however, are sufficient to cause unwanted movements of the craft. Increasing KP and KI values for those axis do not seem to effect the problem. What can be done to return the craft to its former stability and reduce these oscillations? Could there be some other component to blame for this odd behaviour (Noise? Acc calibration? ect.?)
    Link to Bin file:
    https://drive.google.com/file/d/0By12f3-1EZywYnYxbmJpdXltQWc/view?u...
    8.Bin
    Any and all assistance is appreciated.
      Hi Maury,
      Sorry for the late reply!!!
      The high yaw numbers shouldn't be a problem. This is the big change for 3.3. The Yaw controller is different. You may want to try doing the autotune on yaw set to 0.1. If you want to use the 2.2 parameters you need to increase
      RATE_YAW_FILT_HZ to 20. It is currently very low so you may try just increasing it to 4. (I would autotune with aggr of 0.1 though).
      I can't seem to actually see your oscillations in the log you sent.
      Let us know how you go!!
  • Hi,
    Attached is a log from a crash using 3.3 rc5,
    Couldn't find the reason yet
    https://drive.google.com/a/visioncortex.com/file/d/0B5QeAqGnP_rYNkQ...
    Raviv
    2015-07-20 13-13-32 7 crash.bin.log
      Raviv,
      Looks like I need permission to download the log file..
