Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
                  • I'm game to try the failsafe with the buzzer disconnected. I'll report back soon. However: why would the problem arise with 3.3rc7?
              Slight update - I checked another log from a user in Japan who also had an MPU6k failure, and his log also seems related to the battery voltage.  I don't think this changes the advice (RMA the board) but the correlation with the main battery voltage and mpu6k failures may be there but we just haven't noticed it before.
              Thanks again for the log.
              • Hi Randy,
                Thanks a lot to you and Leonard for your analysis. I'll get in touch with 3DR support.
                Fred
              Frederic,
              Leonard and I had a look at the logs and it shows a very unusual problem, not something that we've ever seen before.  It seems that once the battery voltage drops to about 10.3V the MPU6k's Z-axis accelerometer develops a 3m/s bias.  This bias comes and goes very quickly but it messes up the inertial navigation height estimate which causes the vehicle to climb.
              Eventually the battery completely dies and the vehicle comes crashing down because it simply doesn't have the power to remain flying.  That's not unusual but the sudden bias developing on just one IMU is very odd.
              I'd guess this is a variation of the MPU6k issue that 3DR had due to a manufacturing fault.  It looks similar although the bias is much smaller than we normally saw (often we saw 10G of bias developing).  I think this this vehicle was purchased between June 2014 ~ Feb 2015 you could ask for an RMA from 3DR.
              3702883208?profile=original
          • Thanks Randy - I will post the logs later today. I figured the same: low battery, rapid descent. The gain in altitude at failsafe remains a mystery, though. The logs will tell.
  • Hello,
    Normally my copter flies well but after installing 3.3rc7 it started to give bad ahrs error (hud started to move randomly) and an unusual tone (like simonk fw esc's first start tone). Sorry i dont have logs because of cant fly it and didnt minded take a disarmed logs. I reverted back to 3.2.1 and it started to give baro, mag errors and osd started to say high vspeed even copter is disarmed and staying on the ground. I take a risk and tried to fly. It flies but sometimes it force to descend itself, random wobbles, and yaw drifts. Lastly i tried to autotune, yaw drift starts badly and forced itself to descend even full throttle. I switched off autotune and started to wobble badly. At last it landed a position that i cant reach to take copter. Rearmed and it flies again normally. I dont understand whats happening inside really.
    Here is my log
    https://www.dropbox.com/s/q8o0ftper23pwiy/1.rar?dl=0
    1.rar
    Shared with Dropbox
      Yakup,
      So this is an AC3.2.1 log (as you've said) so I only had a quick look at it.  The GPS quality is very bad with HDOP never below 3.97 and number of satellites never above 8.  It detects a number of glitches during the flight.
      If some new equipment has been installed on the vehicle or the GPS has been moved that could point towards the cause.
  • OK, guys, best my novice investigation skills can tell, something has changed recently for tricopters. I'm fairly certain I flew 3.3RC5, but I know I have flown 3.3RC3 or RC4, because I have used the new autotune mode, one axis at a time, and things worked alright, if that gives you some historical reference.
    ANYWAY, in AC3.3RC7, the firmware doesn't seem to take RC7_REV into account, meaning that the tricopter goes into a death spiral as soon as it leaves the ground. I've tried it with RC7_REV = 1 (Normal) and RC7_REV = -1 (Reversed) and there was no change in behavior. It even spins the same direction (to the right, or clockwise when viewed from above). Confirmed that this does NOT happen with AC3.2.1, but not sure when it showed up in AC3.3 (like I said, I have flown versions of AC3.3 without issue, I believe that this is new with 3.3RC7, but maybe I missed RC5, not sure). Log attached below, if that's helpful. They are labeled as they were set, one with Normal servo direction on RC7_REV, and one with Reversed servo direction. Shared via DropBox due to size limitations. Let me know if this is the wrong format or doesn't work.
    Tricopter is currently unflyable. Help me Obi-Wan, you're my only hope.
    https://dl.dropboxusercontent.com/u/1568593/RC7_REV_Normal.BIN
    https://dl.dropboxusercontent.com/u/1568593/RC7_REV_Reversed.BIN
    • Also, how do you get to that page on the wiki for Tricopters? Other than following the direct link, obviously. I had no idea there was a Tricopter page.
        SwissFreek,
        It's been added to the left side menu of the copter wiki now just below Traditional Heli.
        Indeed, we changed the parameter and didn't tell anyone so no wonder you couldn't find it.
sam liked Jimmy Oliver's profile
Aug 25
Mike Whitney liked Mike Whitney's profile
Jul 19
Abdulatif Tlaib liked Ryan's profile
Jun 24
