Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Thanks for the replies. Now I know what to focus on I will try a newer GPS model (when it arrives) and see what happens.
Richard, I am not complaining about the code and I understand it is Beta software. I have been working on this on my own and am not just putting stuff up every time I get stuck (which, until now, has both been rare and I have been able to fix).
That being said, I thought the idea of beta testing is to both get reports of good results and bad ones. I don't have a wood shed but I am happy to have a talk as long as you have something useful to to say that will help me out!! I don't mind being told that I am doing something stupid if it fixes my problem. So far all of the advice has been informative and constructive while helping me to narrow down possible causes.
I think Richard is just kidding around and he's picking up on my weariness re the EKF. The EKF is a fine piece of software but is more complicated than the older DCM/inertial nav and is proving a challenge to get exactly right and there's still some learning we need to do in the wider dev team in how it's acts.
Definitely appreciate both good and bad reports re AC3.3 and we're close to the finale so we should expect it to perform very well at this point.
Hi Randy,
Thanks for the info, I really appreciate the effort. I have another GPS on order and will see if that make the difference.
I have also previously tried replacing all of the GPS cabling and running the system removed from the frame (to get away from interference)
All of my GPS units are 3DR LEA-6H with the original config on two and one of them I have reloaded the config a few times. When plugged into uCentre they all seem to work correctly with no problems.
My next question would be, should I be able to fly in STAB or ALTHOLD without the EKFG Error? Do I need a full 3D position fix every time I fly?
Thanks again for the reply and it gives me more insight than I could obtain on my own but I have learnt a lot about the code etc in the process. I am constantly in awe of the work you guys do and hopefully, one day I can actually be able to contribute something useful!
Alex,
You don't need a full 3D lock if you're only flying in stabilize or AltHold. Ideally bad or missing GPS data shouldn't affect the attitude estimates but I'll ask PaulR to confirm. If bad/missing GPS does affect the attitude then it's something we should fix.
I'm using rc7 and it's almost all fine, i have only troubles when i try to start without GPS signal in mode stabilize.
The led is flashing blue then when the motors are startet the led starts flashing yellow/red. The copter then doesen't fly very good and it's also possible it's losing level.
is this a known issue ?
I have had this happening since 3.3.2 came out. I think randy said that EKF is using GPS to determine position even though GPS is not used in Stabilize mode.
The copter flies fine except you may not have a good home position.
Doesn't always happen but sometimes.
No. Can you attach a log?
https://www.dropbox.com/s/6kruxbbg6oqe47n/2015-07-09%2018-26-01.zip...
This copter is build for acro fun and therefore the main spot wasn't to have low noise on gps or compass. likely more to have as much power as possible for dynamic Flight maneuvers but still to have the possibility to use all the other stuff for missions and so on.
So this is one extreme use case i think and a good base to improve ekf. for now i can't contribute more as providing the test material, if you guys need more logs let me know.
there is an EKF check at the beginning of the log and the Attitude's ErrRP is high-ish which indicates that the EKF doesn't think it has a good roll-pitch estimate. This is really just confirming what you saw, almost undoubtedly this is going to come down to another investigation of the EKF's behaviour.
