Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • No it's the southeast coast of Sweden.
    • this looks a lot like nor cal coast, is it?
      @Maciej: just watching the video can't understand if your quad is well tuned, maybe post here your parameters after Autotune.
      It seems too soft.
      • Sure here are the parameters. It feels much better than the previous autotunes where the quad was very "wobbly" and did overshoot quite a lot.
        3702713672?profile=original
        • Rate Yaw P 0.86??? And i thought mine was high at 0.7
  • Some logs...
    I am still having problems with uncontrolled climbing when speed increases.
    The vibration levels seem very low in the Vibe XYZ.
    This on a 680mm frame with 380kv motors and 15in cf props.
    The uncontrolled climbing is better the EKF filter on, but in loiter and Alt hold the quad looses altitude badly when moved in any direction.
    I suspect some thing hardware related to be causing the other problem I am having. I am hearing a chattering sound when ever i transition from hover to forward flight. Motor or ESC maybe?
    If it is a motor is there a way to see which motor might be causing the problem?
    MissionPlanner.log.2015-07-29
    MissionPlanner.log.2015-07-30
    https://storage.ning.com/topology/rest/1.0/file/get/3702063551?profile=original
    • Round 2....
      2015-07-29 17-08-45 19.bin
      2015-07-30 07-03-10.bin
        Wes,
        The larger of the two logs is from an AC3.2.1 equipped vehicle.  It shows a climb with the classic symptoms of a vehicle with very high vibration: increasing altitude but negative climb rate.  This impossibility shows inertial nav is confused and that's why it climbs.
        The 2nd log is an AC3.3-rc8 log but it's not of an actual flight.  Maybe it's the wrong long?
        • I was trying to post a similar 3.2 log and 3.3 log for comparison I guess I grabbed the wrong 3.3. the correct one is attached, sorry.
          Looking at this 3.3r8 log vibration gets very high. I suppose that is most likely the problem that is causing all of my other problems.
          Some thing in my quad has changed or is failing, it used to fly really well but now is vibrating like crazy.
          Props and motors are rebalanced. The problem is not showing up on the bench, only in flight.
          I have not tried it yet, bet would logging "Motors" be likely to tell me which motor is causing the chattering sound I am hearing?
          If you need another sample of what the vibes should not look like, here it is!
            Wes,
            I don't see the log attached but great that you found the high vibes in the VIBE message.
            I expect the motor output is already being logged (it appears as "RCOU" now instead of "MOT").  My guess is that the motor output will not tell us which motor is bad because even if the vibes are caused by one motor, that vibration will travel through the frame, upset the IMU and result in high spikey output to all motors not just the problem one.  When it's a motor failure, there are strong clues in the motor-output (the bad one goes high, it's opposite goes low) but I suspect we won't see clues in it for this situations.  In the future when we have ESCs that provide feedback (surely they will arrive in 2015) then I image the problem motor may appear as the one that has very high current draw or doesn't obey commands well.
