Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
50 minutes in one flight with one battery pack, mixed flight mode, ultra light carbon frame by "Andrea Beggio", "APM:Copter RC9", "Pixhawk" and "U-Blox M8N" gps.
LiPo 6S 4.6A, total weight 1400g (MTOW).
If anyone is curious here the link to the log (bin): https://drive.google.com/open?id=0B3HEcrNCOga9dHZwSUppRjFVb2c
Interesting the HDOP average (0.6), and the sats number (19), without a single glitch.
@Marco Robustini: Re you 50 mn flight.
Would you mind sharing the motors/props/esc specs?
Thank you very much in advance.
Regards
Henri
Marco,
Really amazing , 50 minutes “is a lot”……
Please can you give more details about the frame and this project….?
For more detail about the frame please contact "Andrea Beggio" via Facebook: https://www.facebook.com/beggio.andrea
Hi Marco,
thanks a lot.
And congratulations for your vídeo, really good
I've just flew new Octa-quad by rc9.
It looks no terrible things happening with not tuned Octa-quad in windy condition;-)
Thank you dev. team!
Hattori-san,
Great, thanks for testing! Although I moan occasionally about frame issues appearing in this thread, the diverse set of vehicles and variations in setups represented in this beta testing group does help greatly in finding the problems.
Now there's a driver for the Lidar Lite V2, do we wire it up with I2C or still PWM? If I2C, will it require any filtering? Got a new blue labeled LLv2 sitting here ready to test : )
Shaun,
I think sticking with the PWM input is probably best. Tridge has found on his sensor that it temporarily started reporting an altitude that was 13m off from reality when using I2C. That's just one sensor though so we don't really have enough data yet to know whether the I2C connection is good or not.
sorry, my pids are really fine... I dont need autotune.
197
198
199
200
201
of 449 Next
