Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Getting the same messages with the unit just sitting on my table. Out in the field it's good... I've also got the odd bad gyro message as well. Again, just sitting still hooked up via usb and making adjustments on the computer.
@ Leonard
Here is the link to the latest AT on rc9. I'm also interested in what you think about the mag interference numbers.
https://drive.google.com/file/d/0B6Nk_i2Lhll5YndwTnVVMG05eVE/view?u...
Really sorry about you crash. I think it's not the baro issue but rather, as Shaun Bell suggests, it's high vibration.
The Z-axis vibes are averaging around 40m/s/s for the most part which is high but perhaps acceptable but there are periods where it's much higher. So for example at the end of the logs they climb way up to 70m/s/s which is unacceptably high. During these periods we also see the contradiction of altitude falling while climb rate is positive - which indicates the EKF is confused.
Perhaps it's not much consolation but on the positive side, the attitude estimate seems to have been good with DCM and the EKF agreeing on the vehicle's attitude.
Yakup,
The best options are listed on the Vibration Dampening wiki page. In particular the 3M foam sold by 3DRobotics or the HobbyKing Orange Foam are the most recommended.
Feel free to add enhancement requests to the issues list. In emergencies we recommend the pilot take-over control in a manual flight mode (like stabilize). I'm not sure we would want to change that and instead have the vehicles act in a special way when the edges of the roll, pitch, yaw or throttle sticks are reached.
In the first image the vibration with the 3M foam sold by 3DRobotics, in the second i use home made antivibration system.
There's no rule, many times an antivibration system works better than another, but only on a specific hardware.
To achieve amazing results with the inertial system you must reduce the vibrations to your board, imperative!
About Autotune: a good altitude where to perform the operation is about ten meters, not less, during this step the throttle stick correction is limited by the autopilot, like in alt-hold, it's not reactive as in Stabilize!
You got pretty bad vibrations and clipping going on. I had the same funny altitude drop and it was the same thing. I was running a Pixhack hard mounted causing the problem. Not sure what ERR19-1 is though.
http://diydrones.com/forum/topics/effects-of-frame-design-on-barome...
I've found that when in autotune, it will loose altitude rather quickly when bringing it back to its starting area. The trick is to bring it back slowly (and add some throttle if necessary to maintain altitude). I've also noticed that the closer it gets to finishing the autotune, the more it will maintain its altitude when bringing it back to the starting area.
I had Mission Planner do the exact same thing. Restarted twice and now it works. Strange.
I had a similar problem with APM Planner II several months ago with 3.2 and it did in fact turn out to be that GC software not the copter FW. Or.... Just for the heck of it try another usb cable perhaps it's defective.
194
195
196
197
198
of 449 Next
