Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • Here is an earlier flight with no issues doing a Circle: 37.bin
        Also I have another copter with similar design and it flies just fine.
  • Just confirming the compass does not need to be recalibrate after 3.3 install  just the accelerometers correct?
    • Did you get confirmation on this? I'm curious too.
      • No... so I guess I'll find out when I update over this coming weekend. I guess not or it would say so. I hope it doesn't because for whatever reason it sometimes takes me MANY tries including the motor compensation before it stops complaining
  • HI,
    Randy or Leonard, cold you please explain what logic is used now for new vibration chart as I am struggling to understand nature of those shakes around time mark 35 on this picture in new Vibs graph when old vibs chart from accelerometers shows nothing is actually vibrating much or any different from other time slots.
    It is a sample from 40Hz filter set that resulted in unusable video as vehicle was constantly jerking in the wind.
    I asked about that again - what specific combination of parameters should be tuned down after an autotune to reduce this effect?
    3702093621?profile=original
    • My simplified explanation of the Vibe results for a single axis is as follows:
      1. The controller takes a running average of the accel output
      2. The Vibe is then computed as the average RMS error between the newest accel data and this average.
      For the curious this is implemented as follows:
      DeviationFromAverage_Squared = HighPassFilter( accelerometer.axis )
      SmoothDeviation_Squared = LowPassFilter( DeviationFromAverage_Squared )
      Vibe.axis = SquareRoot( SmoothDeviation_Squared )
      Significant points:
      1. Smooth or "slow" changes to the accel output will not show up in the Vibe results.
      2. High Vibes indicate that new data is rapidly "bouncing" further on either side of the average than low vibes
      3. Vibe readings will usually not be significantly effected by normal movement or attitude corrections (low frequency inputs)
      4. Vibe will probably show vibrations from these high frequency sources:
      • Motors
      • Propellers
      • Frame vibrations or flex
      • loose objects or wiring flailing around on the aircraft
      • Landing gear resonating
      • High wind buffets causing vibration
      • something else obvious that I forgot
      Having said all of that, I don''t think most controllable (but maybe still sub-optimal) tunes will show much effect on the Vibe results.  The exception might be small and twitchy FPV racers.  I do think vibe results may indicate other issues that cause a poor tune to struggle.
      Which is all a long winded way of saying I don't think PID tuning based on Vibe results is a good way to keep your sanity.  I would use the Vibe results as an indicator that some other mechanical issue is causing problems.
      I could be completely wrong, but this is how I see it.
      • There are 0 mechanical issues and no vibrations of mechanical origin on the platform.
        New Vibrations 3.3 chart shown indicated self-induced shaking of a whole vehicle, mostly on the roll axis from what I can see visually when it is trying to move in the predefined pattern like at circle mode I use for test.
        That is why I provided 2 graphs - from new 3.3 vibes and old accelerometer vibes, as latter one would always show mechanical vibrations right away.
        I agree vibe is not a best method to assess what is happening, but I see no better one yet, and it is not a vibe alone but a delta between old IMU based vibe chart and new 3.3 vibes. Here is an another good sample that shows it all is self-induced from the vehicle tuning logic, as soon as circle mode activated around mark 90 that blue Z axis on the new 3.3 chart goes way up, as before at stable loiter it was calm and normal with no oscillations.
        3702719394?profile=original
        • T3
          Hi Paul,
          the Acc vibrations on your copter look rather small but they seem to have a high frequency noise floor. So there is definitely some vibrations coming from some where.
          You can run an FFT analysis in Mission Planner and check the frequencies causing the problems. Maybe this provides some insight.
          Best regards,
          Thorsten
          • Is there a guide on how to do FFT analysis in MP?
            Those vibrations are not mechanical in my opinion. They also do not show at stable loiter.
            I can hear oscillations and motor voice changing during circle flight and it correlates with severe shaking/jello in video as gimbal cannot handle them and 3.3 vibrations in the log also correlate with that so i still presume it is caused by controller and not by any mechanical issues.
            Also, i just posted 2 screenshots showing those vibrations doubled using 40hz tune, it is same system. Imu based vibs are same, only new 3.3 vibs change.
            I also checked it with accelerometrs on iphone with motors at half power on the ground - there is nothing to see. I have new e305 motors on this vehicle with prfectly balanced props, there is 0 play in any joints. I understand it is easier and usually correct to point back at the hardware but i am out of ideas what to look at.
            So, reverting it all back - what tunable parameters affect speed and aggression of oscillations when code tries to adjust drone's position?
