Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
3.3 RC-10 on "true" Pixhawks with linear dc voltage regulators. (LDO)
Tested on two very different multi rotors.
a) small 500 mm (19.5 inches) quad.
b) medium 1 meter (39.37 inches) hex
They both have frame that don't flex and CF propellers so no fluttering or other kind of prop vibration.
Used the level acc calibration prior flying.Then flew very short time to have a precise view in the log file of the
CTUN (THR_OUT) value that I copied in THR_MID. (I still don't know why this isn't an automatic feature).
Anyway on both these aircraft I tried to:
- take off stabilize
- take off in alt hold fly and land
- take off in Loiter fly and land
Never been so "locked in" even some wind was pushing the aircraft down.
A Heaven for camera handling. Was wondering why I used a 3 axis gimbal with vibration dampening! :-)
As this is before auto tune, I really wonder if I should go through the auto tune ?
Will try longer flights, missions and spline way points tomorrow.
If all goes well, I'll try RC-10 on a medium size (1.2 meter) quad X8 configuration.
Just a note: Prior take off, in Loiter mode, I checked on the telemetry laptop (rfdesign.com.au RFD900+ radio modems) HDOP and numsat which were very good (see log screen below).
Just curious: Where do they place the Pixhawk? :-)
First practically trouble-free flight with v3.3rc10, an AUAV-X1 flight controller on a small carbon tricopter.
I did notice however that I could arm and fly without a GPS lock at all despite ARMING_CHECK set to 1 (enabled), is this normal?
Graham,
Thanks for testing.
That's normal if you're arming in Acro, Stabilize or AltHold mode. If you managed to arm in Loiter, Drift, PosHold or Guided without a GPS lock then I definitely want to see a dataflash log!
Randy,
Since the Wiki doesn't fully explain how to use the Auto tune in 3.3 could you please explain some things.
I understand that it is a flight mode and needs to be entered from a single switch throw from AltHold?
How does one save or discard the Autotune?
What is the suggested starting value for Autotune_AGGR. I have seen some using .10 and some .05; is there no in between?
Hope to try this out on my deadcat tommorow.
Thanks,
Greg
After autotune is completed:
Land with autotune on and the settings are saved.
Land with autotune off and the settings are discarded.
Note that mission planner will tell you, "saving autotune".
As for aggr.. Still not really sure. I know that at .1 my copters are pretty skiddish. At .05 they're doggy lol! I need to do more testing. BTW, all my copters are 960-1300mm hex and X8's. Not to mention 7 to 18kg, so my findings probably don't mean much.
@Shaun Bell: +1 (For size and weight) So at least we are two LOL LOL LOL
My tiny "beating" Quad is 500mm and used exclusively to test new RC-x version.
When things looks "~ok" then I try on real heavy lifters!
So don't feel "alone" ! LOL :-) and your findings often match mine. :-)
Kind regards
Henri
Shaun,
When you say land does that include the requirement to disarm to initiate the save?
Greg,
Yes, you'll need to land and disarm while still in AutoTune (i.e. ch7/ch8 switch high or flight mode set to AutoTune) to save the gains. I've slightly updated the "Changes for 3.3" section of the AutoTune wiki page. Hope that helps a bit.
Certainly we need to add the ability to start/stop/monitor AutoTune from the GCS in future versions of the software.
http://copter.ardupilot.com/wiki/autotune/
The wiki pretty well covers it. I don't know about Autotune_AGGR though. It recommends a range of somewhere between .10 and .05 though.
-Mike
