Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
              • Cool thanks... I think... next you know I'll have yet another project and shy another $500.
                  Hi Richard,
                  There are cheaper frames and if you don't crash you can get away with lighter arms. One of the main advantages of my own 250 design is the arms are replaceable individually but based on the crashes I have had so far I won't have to replace an arm for a long time.
                  So if you find a frame with separate arms the frame will probably be cheaper than a QAV250 and cheaper to fix.
    • what are you pid settings for your qav250? are you running a pixfalcon micro pixhawk?
      because i am and just want to make sure i have the right setttings?
        Hi James,
        Here is my latest QAV250 param list.
        #NOTE: 30/11/2014 7:12:26 PM Frame :
        ACRO_BAL_PITCH,0.2
        ACRO_BAL_ROLL,0.2
        ACRO_EXPO,0.3
        ACRO_RP_P,8
        ACRO_TRAINER,0
        ACRO_YAW_P,4.5
        AHRS_COMP_BETA,0.1
        AHRS_EKF_USE,1
        AHRS_GPS_GAIN,1
        AHRS_GPS_MINSATS,6
        AHRS_GPS_USE,1
        AHRS_ORIENTATION,0
        AHRS_RP_P,0.1
        AHRS_TRIM_X,-0.003750562
        AHRS_TRIM_Y,-0.03652697
        AHRS_TRIM_Z,0
        AHRS_WIND_MAX,0
        AHRS_YAW_P,0.1
        ANGLE_MAX,4500
        ARMING_CHECK,0
        ATC_ACCEL_RP_MAX,162000
        ATC_ACCEL_Y_MAX,54000
        ATC_RATE_FF_ENAB,1
        ATC_RATE_RP_MAX,18000
        ATC_RATE_Y_MAX,13500
        ATC_SLEW_YAW,1000
        BAROGLTCH_ACCEL,1000
        BAROGLTCH_DIST,500
        BAROGLTCH_ENABLE,1
        BATT_AMP_OFFSET,0
        BATT_AMP_PERVOLT,18.0018
        BATT_CAPACITY,1300
        BATT_CURR_PIN,3
        BATT_MONITOR,4
        BATT_VOLT_MULT,10.1
        BATT_VOLT_PIN,2
        BATT_VOLT2_MULT,1
        BATT_VOLT2_PIN,-1
        BRD_PWM_COUNT,4
        BRD_SAFETYENABLE,1
        BRD_SER1_RTSCTS,2
        BRD_SER2_RTSCTS,2
        CAM_DURATION,10
        CAM_SERVO_OFF,1100
        CAM_SERVO_ON,1300
        CAM_TRIGG_DIST,0
        CAM_TRIGG_TYPE,0
        CH7_OPT,14
        CH8_OPT,18
        CHUTE_ALT_MIN,10
        CHUTE_ENABLED,0
        CHUTE_SERVO_OFF,1100
        CHUTE_SERVO_ON,1300
        CHUTE_TYPE,0
        CIRCLE_RADIUS,1000
        CIRCLE_RATE,20
        COMPASS_AUTODEC,0
        COMPASS_DEC,0.143117
        COMPASS_DEV_ID,73225
        COMPASS_DEV_ID2,131594
        COMPASS_DEV_ID3,0
        COMPASS_EXTERNAL,1
        COMPASS_LEARN,0
        COMPASS_MOT_X,-1.134379
        COMPASS_MOT_Y,0.43712
        COMPASS_MOT_Z,-4.985419
        COMPASS_MOT2_X,-0.1665604
        COMPASS_MOT2_Y,1.119968
        COMPASS_MOT2_Z,1.301064
        COMPASS_MOT3_X,0
        COMPASS_MOT3_Y,0
        COMPASS_MOT3_Z,0
        COMPASS_MOTCT,2
        COMPASS_OFS_X,-87
        COMPASS_OFS_Y,-17
        COMPASS_OFS_Z,-78
        COMPASS_OFS2_X,1
        COMPASS_OFS2_Y,-88
        COMPASS_OFS2_Z,-35
        COMPASS_OFS3_X,0
        COMPASS_OFS3_Y,0
        COMPASS_OFS3_Z,0
        COMPASS_ORIENT,0
        COMPASS_PRIMARY,0
        COMPASS_USE,1
        EKF_ABIAS_PNOISE,0.0001
        EKF_ACC_PNOISE,0.25
        EKF_ALT_NOISE,1
        EKF_CHECK_THRESH,0.6
        EKF_EAS_GATE,10
        EKF_EAS_NOISE,1.4
        EKF_GBIAS_PNOISE,1E-06
        EKF_GLITCH_ACCEL,150
        EKF_GLITCH_RAD,15
        EKF_GPS_TYPE,0
        EKF_GYRO_PNOISE,0.015
        EKF_HGT_GATE,5
        EKF_MAG_CAL,1
        EKF_MAG_GATE,3
        EKF_MAG_NOISE,0.05
        EKF_MAGB_PNOISE,0.0003
        EKF_MAGE_PNOISE,0.0003
        EKF_POS_DELAY,220
        EKF_POS_GATE,10
        EKF_POSNE_NOISE,0.5
        EKF_VEL_DELAY,220
        EKF_VEL_GATE,2
        EKF_VELD_NOISE,0.7
        EKF_VELNE_NOISE,0.5
        EKF_WIND_PNOISE,0.1
        EKF_WIND_PSCALE,0.5
        ESC,0
        FENCE_ACTION,1
        FENCE_ALT_MAX,100
        FENCE_ENABLE,1
        FENCE_MARGIN,2
        FENCE_RADIUS,500
        FENCE_TYPE,3
        FLOW_ENABLE,0
        FLTMODE1,0
        FLTMODE2,0
        FLTMODE3,2
        FLTMODE4,1
        FLTMODE5,5
        FLTMODE6,6
        FRAME,1
        FS_BATT_ENABLE,1
        FS_BATT_MAH,300
        FS_BATT_VOLTAGE,10
        FS_GCS_ENABLE,0
        FS_GPS_ENABLE,1
        FS_THR_ENABLE,3
        FS_THR_VALUE,975
        GND_ABS_PRESS,98613.5
        GND_ALT_OFFSET,0
        GND_TEMP,34.15
        GPS_AUTO_SWITCH,1
        GPS_HDOP_GOOD,200
        GPS_MIN_DGPS,100
        GPS_NAVFILTER,8
        GPS_TYPE,1
        GPS_TYPE2,0
        GPSGLITCH_ACCEL,1000
        GPSGLITCH_ENABLE,1
        GPSGLITCH_RADIUS,200
        HLD_LAT_P,1
        INAV_TC_XY,2.5
        INAV_TC_Z,5
        INS_ACC2OFFS_X,1.294651
        INS_ACC2OFFS_Y,1.339363
        INS_ACC2OFFS_Z,1.608879
        INS_ACC2SCAL_X,0.9983891
        INS_ACC2SCAL_Y,1.025331
        INS_ACC2SCAL_Z,0.9866051
        INS_ACC3OFFS_X,0
        INS_ACC3OFFS_Y,0
        INS_ACC3OFFS_Z,0
        INS_ACC3SCAL_X,0
        INS_ACC3SCAL_Y,0
        INS_ACC3SCAL_Z,0
        INS_ACCOFFS_X,-0.08017572
        INS_ACCOFFS_Y,-0.2566303
        INS_ACCOFFS_Z,0.1305826
        INS_ACCSCAL_X,0.9972518
        INS_ACCSCAL_Y,0.9994074
        INS_ACCSCAL_Z,0.9818377
        INS_GYR2OFFS_X,-0.05049829
        INS_GYR2OFFS_Y,0.04734487
        INS_GYR2OFFS_Z,-0.0200304
        INS_GYR3OFFS_X,0
        INS_GYR3OFFS_Y,0
        INS_GYR3OFFS_Z,0
        INS_GYROFFS_X,-0.008267328
        INS_GYROFFS_Y,0.01590531
        INS_GYROFFS_Z,-0.01959998
        INS_MPU6K_FILTER,42
        INS_PRODUCT_ID,5
        LAND_REPOSITION,1
        LAND_SPEED,50
        LOG_BITMASK,-22530
        LOITER_LAT_D,0
        LOITER_LAT_I,0.5
        LOITER_LAT_IMAX,1000
        LOITER_LAT_P,1
        LOITER_LON_D,0
        LOITER_LON_I,0.5
        LOITER_LON_IMAX,1000
        LOITER_LON_P,1
        MAG_ENABLE,1
        MIS_RESTART,0
        MIS_TOTAL,0
        MNT_ANGMAX_PAN,4500
        MNT_ANGMAX_ROL,4500
        MNT_ANGMAX_TIL,4500
        MNT_ANGMIN_PAN,-4500
        MNT_ANGMIN_ROL,-4500
        MNT_ANGMIN_TIL,-4500
        MNT_CONTROL_X,0
        MNT_CONTROL_Y,0
        MNT_CONTROL_Z,0
        MNT_JSTICK_SPD,0
        MNT_MODE,0
        MNT_NEUTRAL_X,0
        MNT_NEUTRAL_Y,0
        MNT_NEUTRAL_Z,0
        MNT_RC_IN_PAN,0
        MNT_RC_IN_ROLL,0
        MNT_RC_IN_TILT,0
        MNT_RETRACT_X,0
        MNT_RETRACT_Y,0
        MNT_RETRACT_Z,0
        MNT_STAB_PAN,0
        MNT_STAB_ROLL,0
        MNT_STAB_TILT,0
        MOT_SPIN_ARMED,70
        MOT_TCRV_ENABLE,1
        MOT_TCRV_MAXPCT,93
        MOT_TCRV_MIDPCT,52
        OF_PIT_D,0.12
        OF_PIT_I,0.5
        OF_PIT_IMAX,100
        OF_PIT_P,2.5
        OF_RLL_D,0.12
        OF_RLL_I,0.5
        OF_RLL_IMAX,100
        OF_RLL_P,2.5
        PHLD_BRAKE_ANGLE,3000
        PHLD_BRAKE_RATE,8
        PILOT_ACCEL_Z,250
        PILOT_VELZ_MAX,250
        POSCON_THR_HOVER,531.7854
        RALLY_LIMIT_KM,2
        RALLY_TOTAL,0
        RATE_PIT_D,0.015
        RATE_PIT_I,0.9
        RATE_PIT_IMAX,1000
        RATE_PIT_P,0.225
        RATE_RLL_D,0.0065
        RATE_RLL_I,0.2
        RATE_RLL_IMAX,1000
        RATE_RLL_P,0.05
        RATE_YAW_D,0.005
        RATE_YAW_I,0.04
        RATE_YAW_IMAX,1000
        RATE_YAW_P,0.4
        RC_FEEL_RP,50
        RC_SPEED,490
        RC1_DZ,2
        RC1_MAX,2015
        RC1_MIN,990
        RC1_REV,1
        RC1_TRIM,1502
        RC10_DZ,0
        RC10_FUNCTION,0
        RC10_MAX,1900
        RC10_MIN,1100
        RC10_REV,1
        RC10_TRIM,1500
        RC11_DZ,0
        RC11_FUNCTION,0
        RC11_MAX,1900
        RC11_MIN,1100
        RC11_REV,1
        RC11_TRIM,1500
        RC12_DZ,0
        RC12_FUNCTION,0
        RC12_MAX,1900
        RC12_MIN,1100
        RC12_REV,1
        RC12_TRIM,1500
        RC13_DZ,0
        RC13_FUNCTION,0
        RC13_MAX,1900
        RC13_MIN,1100
        RC13_REV,1
        RC13_TRIM,1500
        RC14_DZ,0
        RC14_FUNCTION,0
        RC14_MAX,1900
        RC14_MIN,1100
        RC14_REV,1
        RC14_TRIM,1500
        RC2_DZ,2
        RC2_MAX,2016
        RC2_MIN,991
        RC2_REV,1
        RC2_TRIM,1506
        RC3_DZ,20
        RC3_MAX,2016
        RC3_MIN,991
        RC3_REV,1
        RC3_TRIM,991
        RC4_DZ,3
        RC4_MAX,2016
        RC4_MIN,991
        RC4_REV,1
        RC4_TRIM,1506
        RC5_DZ,0
        RC5_FUNCTION,0
        RC5_MAX,1822
        RC5_MIN,1165
        RC5_REV,1
        RC5_TRIM,1422
        RC6_DZ,0
        RC6_FUNCTION,0
        RC6_MAX,2016
        RC6_MIN,992
        RC6_REV,1
        RC6_TRIM,1503
        RC7_DZ,0
        RC7_FUNCTION,0
        RC7_MAX,2016
        RC7_MIN,991
        RC7_REV,1
        RC7_TRIM,1504
        RC8_DZ,0
        RC8_FUNCTION,0
        RC8_MAX,2015
        RC8_MIN,991
        RC8_REV,1
        RC8_TRIM,1503
        RC9_DZ,0
        RC9_FUNCTION,0
        RC9_MAX,1900
        RC9_MIN,1100
        RC9_REV,1
        RC9_TRIM,1500
        RCMAP_PITCH,2
        RCMAP_ROLL,1
        RCMAP_THROTTLE,3
        RCMAP_YAW,4
        RELAY_PIN,54
        RELAY_PIN2,-1
        RELAY_PIN3,-1
        RELAY_PIN4,-1
        RNGFND_FUNCTION,0
        RNGFND_GAIN,0.8
        RNGFND_MAX_CM,700
        RNGFND_MIN_CM,20
        RNGFND_OFFSET,0
        RNGFND_PIN,-1
        RNGFND_RMETRIC,1
        RNGFND_SCALING,3
        RNGFND_SETTLE_MS,0
        RNGFND_STOP_PIN,-1
        RNGFND_TYPE,0
        RNGFND2_FUNCTION,0
        RNGFND2_MAX_CM,700
        RNGFND2_MIN_CM,20
        RNGFND2_OFFSET,0
        RNGFND2_PIN,-1
        RNGFND2_RMETRIC,1
        RNGFND2_SCALING,3
        RNGFND2_SETTLE_M,0
        RNGFND2_STOP_PIN,-1
        RNGFND2_TYPE,0
        RSSI_PIN,-1
        RSSI_RANGE,5
        RTL_ALT,1500
        RTL_ALT_FINAL,0
        RTL_LOIT_TIME,5000
        SCHED_DEBUG,0
        SERIAL0_BAUD,115
        SERIAL1_BAUD,57
        SERIAL2_BAUD,57
        SERIAL2_PROTOCOL,1
        SIMPLE,0
        SR0_EXT_STAT,2
        SR0_EXTRA1,10
        SR0_EXTRA2,10
        SR0_EXTRA3,2
        SR0_PARAMS,10
        SR0_POSITION,3
        SR0_RAW_CTRL,0
        SR0_RAW_SENS,2
        SR0_RC_CHAN,2
        SR1_EXT_STAT,2
        SR1_EXTRA1,5
        SR1_EXTRA2,2
        SR1_EXTRA3,0
        SR1_PARAMS,0
        SR1_POSITION,2
        SR1_RAW_CTRL,0
        SR1_RAW_SENS,2
        SR1_RC_CHAN,5
        SR2_EXT_STAT,0
        SR2_EXTRA1,0
        SR2_EXTRA2,0
        SR2_EXTRA3,0
        SR2_PARAMS,0
        SR2_POSITION,0
        SR2_RAW_CTRL,0
        SR2_RAW_SENS,0
        SR2_RC_CHAN,0
        STB_PIT_P,10
        STB_RLL_P,11.25
        STB_YAW_P,4.5
        SUPER_SIMPLE,0
        SYSID_MYGCS,255
        SYSID_SW_MREV,120
        SYSID_SW_TYPE,10
        SYSID_THISMAV,10
        TELEM_DELAY,0
        TERRAIN_ENABLE,1
        TERRAIN_SPACING,100
        THR_ACCEL_D,0
        THR_ACCEL_I,1
        THR_ACCEL_IMAX,500
        THR_ACCEL_P,0.5
        THR_ALT_P,1
        THR_DZ,100
        THR_MAX,1000
        THR_MID,500
        THR_MIN,130
        THR_RATE_P,6
        TRIM_THROTTLE,531
        TUNE,0
        TUNE_HIGH,15000
        TUNE_LOW,4000
        WP_YAW_BEHAVIOR,1
        WPNAV_ACCEL,500
        WPNAV_ACCEL_Z,100
        WPNAV_LOIT_JERK,1000
        WPNAV_LOIT_SPEED,1500
        WPNAV_RADIUS,200
        WPNAV_SPEED,1500
        WPNAV_SPEED_DN,150
        WPNAV_SPEED_UP,250
      • 3702721666?profile=originalAUAV-X2
  • This reply was deleted.
    • Hey Horsj
      As I understand it, the landing gear won't activate (as in retract) automatically - that's something that should be corrected on the wiki - but it should deploy automatically either if you choose landing mode or if it goes into a landing mode in any automated mode (auto or rtl).  I don't think the middle switch position matters at this point, in my experience it's either on or off, and the auto deploy should still work in 'on'.
    Noticed a couple things using the latest 3.3 rc1x, I'm flying a small carbon tricopter with the AUAV-X1 flight controller.
    1) ResetToArmedYaw (CH7/8 option) doesn't work, info from a search reveals it has never worked, is there a plan to get this working? (it's not quite the same as Simple mode)
    2) Autotune weirdly doesn't seem to work for me, I've set AUTOTUNE_AXES to 4 (to tune yaw only) but when in ALT_HOLD and I switch CH7 (Autotune) to high nothing happens. Is this tricopter specific?
    3) The loss of altitude problem in ALT_HOLD forward flight is very noticeable on this airframe (not in this log), however to clarify this and to hopefully add to it's understanding, there is no loss of altitude DURING the actual forward flight, however the loss and recovery only occurs AFTER the pitch stick is released and the copter is drifting forward while level, it's almost as if the altitude controller can't catch up properly or overreacts to the sudden change in attitude?
    Log attached (two attempts to autotune and one to ResetToArmedYaw)
    3702104118?profile=original
    2015-10-04 10-06-33.log
    https://storage.ning.com/topology/rest/1.0/file/get/3702104051?profile=original
      Hi Graham,
      The reason Autotune won't start is because you have not centred your throttle stick. You are asking for an altitude change and it is pausing auto tune until you centre the throttle stick.
        Thanks Leonard, what value center throttle is it waiting for? My throttle in was 1583 for the first one, is it looking for exactly 1500?
          Had lowered the throttle deadzone so center throttle was more elusive than necessary, thanks again.
