Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
        • Nice vibration levels, but I'm afraid removing gnd wires from ESCs on pixhawk is a recepy for disaster due to known sync loss issues especially with low kv high voltage, high pole count motors + SK/blheli ESCs.
          • This reply was deleted.
            • Castle are well known for quality they also tend to be rather expensive. Since July I use HW xRotor40a-Pro, with breaking enabled they are as as fast as spiders 40a flashed with blheli on low kv otors, but barelly get warm.
            Ah, I didn't notice that change.  I've heard this same info from Rob Lefebvre.
          Joe,
          Yes, that's looking very good.  Vibe levels are certainly much lower than on my IRIS (which I think is a decent example of an average well built copter).  The z-axis is slightly lower and the x and y axes are much much lower.  Nicely done!
      • This my pids: I'm not an expert but, perhaps give you an idea to begin, Pitch is higher (in my case and yours) because the copter have to do more esford to move on that side, batteries are larger to there and a camera, gimbal etc. first to tune be shure that your center gravity is correct in both sides, set your gimbal as near as the main plates as you can; as Leonardthal recommend, do a first autotune and then a second one to fine tune; if you don't like your results, download them by steps, the axis that you don't feel comfortable, you have an easy basic tunning page, try with it first
        3702723778?profile=originalThis only an orientation, remember that I don't finish to tune yet, but flies good, Good luck
        PD: here you have an autotune topic with good information and where you can post your tune advances http://diydrones.com/forum/topics/ac-3-1-autotune-support-discussio...
      • Very similar than my new build  http://diydrones.com/forum/topics/optimizing-my-first-cuad?id=70584...
        I did autotune but without the gimbal in front, then I lower stab pich and roll and rates pitch and roll but pitch stay higher, then I try a second autotune but abort in roll for a lost signal problem and now waiting a calm day to re do for a fine tunning but the copter is flying well, I have to put a cover, look my post. If you want, I can share my actual pids
    • Perhaps it's usefull if you share a photo of your build, It's looks strange that you have so higher values in Roll than Pitch, did you complete well Pitch and yaw autotune?
      It's usefull for experts if you share your autotune log too.
    Ok, there seems to be a problem with the centralised builder which is stopping the release candidate from appearing in the mission planner.  It's getting late in Asia so I suspect it will be a 12h+ delay before it's out.
    • Thank you for the effort Randy!
      I had this bug once. i was ready to take off then a storm of birds was passing by so i immediatly abort the take off.
      At re arming the iris took off immediatly. I take it down with the rc controller due to the strange fact and then i power cycle the iris. By luck i didn't engage the missions stored on the iris after the strange take off.
        @frederico,
            yes, you got lucky there.  That's the exact case where it gets itself into a bad state.
        @Hien,
            ok, sorry for the troubles!
        To add a bit more detail, internally Copter has an auto-armed flag that should always be true if the vehicle is flying autonomously.  It's primary function is to stop the vehicle from beginning an autonomous mission unless the user has raised the throttle.  In the case of the take-off being initiated from the ground station we were not checking that flag.
        Copter-3-3.1-rc1 has appeared in the mission planner so all feedback welcome.
        It actually has some additional changes beyond this fix:
        • compiler updated to 4.9.3 (code runs slightly faster than with older 4.7.2 compiler)
        • TradHeli changes ahead of next round of beta testing (should not affect multicopters)
