Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • I guess no one seems concerned, I deleted my logfile.
          Hard to say what happened but the accel[1] not healthy indicates a (perhaps temporary) hardware failure of one of the two IMUs (the LSM303d to be precise).  I'm not sure what we could do about that.  In Copter-3.3 it's possible to disable an IMU completely (INS_USE, INS_USE2 parameters) but it's not recommended really. Better to replace the board if one IMU is failing regularly.
          • Is this because it can't read values from the IMU? I get this also from time to time with my AUAV-X2. Usually disconnecting / reconnecting the battery cures it but it would be nice to know why it happens.
              Yes, it's likely that it's not responding to requests.  I'm more of a software person but perhaps it could be because the power is not coming up quickly enough or the board voltage is too low (i.e. if USB power cable or PC it's attached to can't provide enough power so voltage sags).  It could be a bad solder joint on the connection somewhere.
              • Thanks for the hints. I'll try this again with my flight battery. But other tests with the USB cable seem to be ok now.
                I've powered it up from the same USB cable a few times now and I haven't been able to repeat the issue.
                I can't say that it's gone forever, but at least I don't seem to have a hard permanent failure.
    • Thanks for all the Dev's work on the new release.
      So I previously was using 3.2.1 and it was working.
      I now loaded 3.3.1 on my PixHawk on my desk, only using my USB cable for the power to the PixHawk (as I have often done).
      The firmware flash seemed to go ok. I power cycled.
      I keep getting errors that I don't remember seeing before:
      PreArm: Accelerometers not healthy
      So I went to do the Initial setup, and tried the Accelerometer calibration.
      Then I get this error:
      Place vehicle level and press any key.
      Initialising APM...
      Initialising APM...
      Calibration FAILED
      Ok, what do I do? Why do I get an accel[1] not healthy? I can't remember ever seeing this before.
      Or, MUST I test this with a flight battery, and not only powering the PixHawk with my USB cable?
      Thanks for any hints!
  • An observation.
    Yesterday I tried Auto Tune. The copter would not hold altitude while in Alt Hold, which is commonly reported by many. The AT was aborted and I discovered the vibration levels had worsened.
    Today after improving the vibration levels by > one order of magnitude, during AT the copter held altitude much better.
    Confirmation bias or a connection?
      DG,
      Great that you got the vibes reduced that much.
      Bad vibrations will certainly affect AltHold performance.  It's absolutely critical and we recommend people designing/building copters to check their vibration levels (see First Flight section's Measuring Vibration wiki page) and the live vibration monitor added in Copter-3.3 was added to try and make doing this a little easier.
  • Leonard/Randy,
      If you get time, would you please look at these Auto Tune results for my latest quadcopter build? It's an H4 Alien 680. The props are APC 13x5.5 MR, smaller than desired, but I could not find the adapters for the 14".  It had one squirrely event during roll while AT, but other than that it went smooth.
    Why is the Stab Pitch and Roll so diverged? The COG is darn close, and it seems to fly ok, although only flew it for a few minutes in perfectly still winds :)
    Link to flight log
    https://www.mediafire.com/?rl6u4rqdx99c52x
  • Hello,
    I'm unable to use my tarot t2d gimbal with 3.3 on pixhawk. I have been using it connected directly to my rc on channel 6. Today, I setup the camera gimbal on mission planner to RC9 output / rc6 input according to the wiki. The gimbal initializes with the blue led steady ( no signal )  and the cam pointed to the front ( horizon ). When I press the motor switch , the blue light starts blinking and the camera turns downward, but I'm unable to control it with the RC6 switch.
    Could someone confirm that it is working with 3.3 version and perhaps point me to a soution?
    Many thanks in advance
    2015_10_24_gimbalproblem.param
    https://storage.ning.com/topology/rest/1.0/file/get/3702114094?profile=original
