Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
May be off topic, but I'd like to stress the issue of compass interference. I just recently re-assembled my new Alien 680 build by swapping out the KDE ESC's that I just could not get to work right with AC. In went the HW Quattro and it has zero issues. Go figure.
So I'm going through the motions and EKF is yelling at me again. Looked at the graphs (love that feature) and there it was; compass into the orange. Drat. The mast is 6"+ from the top of the frame, the main power is underneath. Huh? I demag all steel screws. The rest are non-mag SS.
Then I noticed a live 12v JST connector for the gimbal poking out through a slit on the top frame. Hmm. Tucked it down inside the frame, EKF is happy, I'm happy. Does that sound logical or just coincidence? Are compasses that sensitive?
I will try to recreate the compass interference warning. This wire is off the 12v step down regulator, and my understanding is when there is no return path for the current, an exposed wire can emit radiated EMI. No?
I will be interested to hear your results. I can't see enough EMI from a low voltage open conductor to cause compass interference.
Hi! I did another test flight with my tbs discovery. I was a bit windy last day. but everything went fine. I raised my quad to 60m without problem, then raised it up to 100-120m and held it there for a few seconds then returned down and landed safely. I reviewed my logs after finding out a very surprising info. My current draw peaked to almost 60A
my setup is this:
sunnysky 900kv 2216
gemfan 1045 carbon nylon mix
DYS 30A V2 esc (blue)
5200mah 10C multistar 4s
normally I see my current draw below 30A. I was bothered after I found out about the current draw. Can somebody analyze my log? I will attach the file. thanks!
2015-10-31 17-48-31.bin
2015-10-31 17-48-31.log
Hi Randy,
can you help me analyze my log?
altitude and current draw log. Are the spikes caused by glitch? my esc's are running fine after the flight
by the way, I have performed current calibration prior to this by doing this method:
1.Fully charge your lipo
2. Immediately fly your multi for at least five minutes
3. Land and disconnect the lipo from the multi
4. Immediately, charge your lipo unti full using a smart charger with display (capable of displaying total current used for charging the lipo to full capacity).
5. Connect your FC to mission planner using usb cable and open the Battery monitor sub-tab in Initial Setup>>Optional Hardware tab
6. Look at the Amperes per Volt value
7. Go to Flight Data tab and download data flash logs
8. Review the log file and check the CurrTotal
9. Calibrate the current sensor by adjusting the Amp per volt to actual values. Do the math:
New Amp per Volt = Amp per volt * Total Charge / CurrTotal
10. Type the new Amp per Volt value on the box provided in mission planner for the calibration.
Hello! I would like to share with you the altitude controller's amazing performance when powered with XL-EZ4 rangefinder.
It is extraordinary how precisely it can control the altitude, even in extreme low height flight.
Thanks Arducopter team!!!
https://youtu.be/-ZtkwyXZ_cA
Frame: Tarot 680 Pro with 4.4Kg auw weight
I am really looking forward to fuller integration of range finders,(during auto missions)and the potential for obsticale avoidance by adding a second forward facing range finder. 3.4 maybe?
Dreaming I know, but 10 years ago who have ever imagined civilians drone in the hands of hobbist running auto missions?
Please Randy, and rest of the development team, tell us how we can help to move development forward!
Thank you again!
