Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Do the latest firmwares support V and T setup for hexacopters at all?
I have used standard Octocopter code to fly an H-shaped Octocopter (like your hex shown, but with 8 rotors). It worked out OK.
Duffy,
I'm afraid we only support X and + for the Hexacopters. It's not super hard to add support, just need to come up with the motor mixing for roll, pitch and yaw.
http://www.robotshop.com/en/lidar-lite-2-laser-rangefinder-pulsedli...
It would be nice to have the option use the installed sonar or lidar, either way OF is really neat feature.
I am interested in the answers to your questions also!
Looking forward to an icon in mission planned to enable PX4Flow as a near plug and play option, with a calibration sequence similar to setting the Acc or compass.
All is good time I am sure.
It's normal that I start autotune with
ATC_ACCEL_P_MAX,72000
ATC_ACCEL_R_MAX,72000
and after autotune I have
ATC_ACCEL_P_MAX,49814,88
ATC_ACCEL_R_MAX,51907,54
ATC_ACCEL_Y_MAX,12720,53
Tnx
Yes, these parameters are tuned on autotune routine. How are your copter flying with them?
I'm satisfied but just after second autotune The first wasn't good (autotune>save>autotune>save)
I have large x8 8 kg
This procedure was recommended a few times. The autotune takes the currrent parameters as the starting point, thus , doing it two times would make the parameters more refined.
If they are OK, with no wobbles, enjoy it!
Hi!
I tried to use battery_voltage2 and current2, readings get to Pixhawk but scaled wrong?
I received 15355V, tried to scale it to 15,3V but then I only get 15V. Using a standard power module connected to ADC 3.3V.
Want to use 2 batteries in parallell and monitor each via separate power modules?
Great job with the new version....
//Affe
79
80
81
82
83
of 449 Next
