Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • Lidar lite v2 is only 115.00.
        http://www.robotshop.com/en/lidar-lite-2-laser-rangefinder-pulsedli...
        It would be nice to have the option use the installed sonar or lidar, either way OF is really neat feature.
        • I live outside their country, and shipment to my place is unusually high.
          I agree, having such option would be great.
          Tried to calibrate OF, but it seems without lidar flowX/Y and bodyX/Y are poorly correlated, scaling will not make them match (bodyX/Y and GyrX/Y do match).
    • I would say I am right there with you, but you have clearly thought this through more deeply than I have. I am getting ready to mount a px4flow but have not entirely wrap my mind around when OF works and if by using it I loose functionality some where else.
      I am interested in the answers to your questions also!
      Looking forward to an icon in mission planned to enable PX4Flow as a near plug and play option, with a calibration sequence similar to setting the Acc or compass.
      All is good time I am sure.
  • It's normal that I start autotune with
    ATC_ACCEL_P_MAX,72000
    ATC_ACCEL_R_MAX,72000
    and after autotune I have
    ATC_ACCEL_P_MAX,49814,88
    ATC_ACCEL_R_MAX,51907,54
    ATC_ACCEL_Y_MAX,12720,53
    Tnx
    • Yes, these parameters are tuned on autotune routine. How are your copter flying with them?
      • I'm satisfied but just after second autotune The first wasn't good  (autotune>save>autotune>save)
        I have large x8  8 kg
        • This procedure was recommended a few times. The autotune takes the currrent parameters as the starting point, thus , doing it two times would make the parameters more refined.
          If they are OK, with no wobbles, enjoy it!
  • Hi!
    I tried to use battery_voltage2 and current2, readings get to Pixhawk but scaled wrong?
    I received 15355V, tried to scale it to 15,3V but then I only get 15V. Using a standard power module connected to ADC 3.3V.
    Want to use 2 batteries in parallell and monitor each via separate power modules?
    Great job with the new version....
    //Affe
      Affe,
      I've never tried to monitor two batteries but it should work if you make most of the BATT2_ parameters the same as the equivalent BATT_ parameters.  We don't us the measurements from the second battery monitor for anything (i.e. battery failsafe) but I think you should be able to see the values in the Mission Planner (or other GCS perhaps) as "battery_voltage2", etc.
      • Randy,
        You are right I can see some values in MP but as I wrote I cant scale them correct without loosing the decimals?
        My settings for batt2:
        BATT2_MONITOR -> 4        (Analog Voltage and Current)
        BATT2_VOLT_PIN-> 13       (in MP A12 not sure if this is right since it is numbered 13 in the Picture in wiki)?
        BATT2_CURR_PIN-> 14      (in MP A13 not sure if this is right since it is numbered 14 in the picture in wiki)?
        And I have only connected pin 3,4 and 6 from Power module, and they are connected to ADC 3.3V on pin 2,4 and 5 and in that order.
        pixhawk1
        It is a quite Heavy X8 so I was thinking i might go over 60A if I run them via one Power module, and as I was having one spare, so why not try it this way?
