Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • Sorry Randy - forgot to attach the logfile.
    In this log, I was flying in RC controlled mode, always connected to Tower.
    I landed, disarmed, then re-armed in Tower, pressed Takeoff and went into FollowMe. Then I pressed Pause and the drone immediately banked away. I could rescue by switching flight modes on my RC. (in panic I switched to Auto for a split second - this was not the reason)
    I reproduced this in another flight, after pressing Takeoff in Tower, I pressed Pause when the drone banked away again.
    I would classify this as a "flyaway" kind of defect. AC3.3.2, latest Tower release, Lidar enabled.
    Thanks for looking into this.
    84.zip
    • Hi Stephan,
      Do you also have access to the tlog files for this issue?
      - Fredy
      Tower lead developer
      • Hi Fredy,
        I am currently on a business trip- will get back to you by Thursday
        Thx Stephan
    • Tried this today with fw 3.3.3 and tower app.
      Just to make sure that I did everything the same way:
      1. Armed in stabilize and took off
      2. switched to pos hold
      3. switched to follow me in tower
      4. walked around with the drone following
      5. switched to pause in tower
      The drone did what it shoud - it stopped in Loiter.
      Did this error only happen when drone is armed via tower?
    • That's a little dramatic :)
      • Well for someone less experienced it would have likely ended crashing somewhere in the wild.
        So yes, I would consider the incident serious.
        • Apologies, the f-ing forum software truncated my answer again..  I was also  trying to say that the term 'flyaway' seems to be used for circumstances where you lose complete control of the craft and nothing you do regains control.  There are lots of circumstances where it can behave unpredictably or erratically in various automated modes (toilet bowling, gps glitches, various recovery or failsafe actions, gcs bugs etc etc) but if you can flick it back into stabilise mode and regain control or into RTL and have it return, then from what (little) I understand then this isn't classed as a 'flyaway'.  In guided mode you're somewhat at the mercy of the GCS, although it's possible it's a bug in the guided mode itself.
          It's an important distinction - phantoms are well known for proper flyaways where it's impossible to regain any kind of control, whereas it's extremely rare in APM (not bashing phantoms, just an example that comes to mind).
          • This reply was deleted.
              Let's all cool down here.  No more comments on this until I review the logs please.
