Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
You may notice that Copter-3.3.3-rc1 is now available through the Mission Planner's beta firmware link. It's a fairly minor change as you can see from the changes below (and Release Notes here) but any testing would be appreciated.
I must admit it got dark before I was able to test fly the exact firmware that the MP is dispensing but I will tomorrow morning and report back (I'm 99% sure it's fine but you might want to wait 15h just in case).
Changes from 3.3.2
1) Restrict mode changes in helicopter when rotor is not at speed
2) add ATC_ANGLE_BOOST param to allow disabling angle boost for all flight modes (requested by XCraft whose vehicle provides lift when leaned over)
3) add LightWare range finder support
OK, for a first time, I think, ever, I got an error from MP software claiming 'query error' when it tried to download firmware.
I just updated MP to latest beta and tried to flash 3.3-rc1 it fails every time it tries to get a firmware file.
It is same error for quad and hex.
Hey Randy, I think it would bring a lot of benefits to integrate RSSI from ppm stream from one of the channels, like it is already done in Ardu Pilot firmware, are there some resources issues or its simply didn't make it yet into the copter?
I've test flown this this morning and it flew beautifully. Thanks everyone for your help with the beta testing!
Thank's Randy, any LightWare model is included? this is included? http://www.lightware.co.za/shop/en/proximity-sensors/24-oslrf-01.html
I don't think that oslrf you linked above will work because it's missing the analog and I2C interfaces.
By the way, the analog Lightware range finders were supported from Copter-3.3 but it's the I2C connection that's new with this release candidate. Sorry, the release notes are not clear on that.
I've never personally used the Lightware rangefinders but Tridge really likes them and says they're very reliable. From looking at the website I would go for the SF02 with the 50m range and $300 price. That's not particularly cheap but that's what I'd go for if I were in the market.
So, is that laser range finder take over all the function of barometer ?
Or, Light ware may be utilized for landing mode by the limitation of the range.
I'm curious how these things work over water... can't find any documentation on that. I emailed the company that makes the SFO2/2 about this waiting for a reply.
Note their reply. I'll be buying one next summer! Good to know they have worked on the over the water issue!!
"Dear Rick,
Google it : SF11 Laser Altimeter , to find PDF about it
43
44
45
46
47
of 449 Next
