Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Hi Randy,
Thanks for the reply!
I used the serial port.
SERIAL4_PROTOCOL=9SERIAL4_BAUD=19200RNGFND_TYPE=8(LightWareSerial)RNGFND_SCALING=1RNGFND_MIN_CM=5RNGFND_MAX_CM=2500RNGFND_GNDCLEAR = 15Checked the Lightware with the analog and with a pc and works.
Just wanted to make sure its fully tested and if anyone else tried it yet.
Raviv
Just tested IRIS+ with new 3.3.3 software. Tried only on Althold flight mode for about 6 minutes. Probably its placebo effect, but feels like brand new LOL
We’ve release Copter-3.3.3 today which is just a renamed version of Copter-3.3.3-rc2. To recap it has these over 3.3.2 (Release Notes):
1) bug fix to Guided mode's velocity controller to run at 400hz
2) bug fix to MAVLink routing to allow camera messages to reach MAVLink enabled cameras and gimbals (including SToRM32)
3) Restrict mode changes in helicopter when rotor is not at speed
4) add ATC_ANGLE_BOOST param to allow disabling angle boost for all flight modes
5) add LightWare I2C range finder support
Separately it looks like the Pixracer issues are mostly resolved and we plan to push out a special Copter-3.3.4-pixracer tomorrow.
Thanks all for your testing!
It is clear that you have bad GPS reception. It may be caused by GPS receiver low quality, bad cables or GPS jamming if it is close to a transmitter.
Do you have the GPS on long pole above the radios and the FPV transmitter?
The cabling is not very good. It is better to have them tighten together to the platform, not spread in the air. Use braided shields to have proper cable runs.
To protect the GPS from the inferences can use aluminum foil glued below the GPS body(all the black lower body.
Thanks Randy and all the team for the hard work!
Many Thank's Randy for all you and your team esfford. :)
I have had a few near collisions with buildings in Loiter mode, as the GPS has a glitch. I took it out in a clear area to test for this and it did it there. I have included the log file, and you can see at about 5:10, several things go crazy with EKF readings. If you turn on "use map" you will see that it was nearly back to me in the south west corner of the flight, and it takes off to the north west for about 30 feet, then comes back. This is very disturbing and will keep me from using this system until we know what is causing it.
I also have noticed that if the temp is below 50 degrees, Pixhawk reports that it has bad accelerometer health and inconsistent compass, until I warm it, then I have to keep it powered or it starts this again. It seems to work fine at room temp, and I am calibrating it regularly.
This is on a new Pixhawk, with Copter V3.3.3-rc2
I hope these are known issues with a solution.
Thanks,
Rick
2016-02-20 12-11-22.bin
I bought a new uBlox GPS unit from 3DR and replaced the cables to it, and started completely over setting up with the latest firmware and I am still getting these temporary deviances in perceived position. This is terrifying in that it is very dangerous to me and anyone around me. It also does this while flying missions, so when it recovers from its problems, it gives up on the mission it is running and decides to land, so now I can't rely on it for anything. I seriously think this is a problem with the Pixhawk. This is on a real Pixhawk from 3DR, that is a replacement for the one that had a known defect, but couldn't be replaced until after that one destroyed my quad. Fortunately, nobody was hurt in that one. This is just as dangerous. Can Randy or someone please look at my data and tell me if I am right? Suggesting that I buy more new equipment is not really what I'm looking for with this issue, either.
Do you have a camera or video equipment near? Can you share a photo how your gps is attached? perhaps that helps.
19
20
21
22
23
of 449 Next
