Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Plus 10 !! Yes I think it should named 4.0 just the facts .. dropped APM Also EKF on as default ..etc .. as you guys say there has been a lot of changes .. why not let APM 8bit have .. 3.2.1...2..3..4..5.. etc and 32bit controllers Have 4.0 ...1..2..3..4 etc
That would be a great idea.
I think its ok to go for a new major relase just because you drop APM support.
ATM it is allready confusing which Mission Planner works best with which firmware.
Cheers
Axel
Is RC2 still in time for upcoming weekend?
@Dom,
It's not looking great for this weekend. A lot of changes have gone in over the past two weeks and there have been some complaints within the dev team that it's become very hard to get the EKF position estimate to settle so that the pilot can enter Loiter, etc. We need to resolve that before we push it out or it will just annoying everyone far too much.
@Randy
Thanks for letting me know! What this EKF problem is about? I am just finishing my new copter, including landing gear. I planned to use the RX/TX for that but with the new features I would like to plug it on the FC.
What nightly build you would suggest with working auto tune? I want to do the maiden flight at weekend
The problem is basically trying to walk the tightrope between EKF initialization being too strict and taking too long. Or being too lax, and having bad initializations leading to potential crashes.
This post is actually about an incident with a 3.2.1 large quad, but the fix should go in the next release. I have been flying a very large 14kg quad and all was going rather well with the exception of a lack of power. But what happened was avoidable by myself and by the firmware.
I had a brown out due to a bec on the servo rail providing voltage at 5.8-5.9 instead of the 5.5 it was supposed to be putting out. Running the auto-analysis in mission planner never raised any red flags about this high voltage.
I could have prevented the total loss of control by having a second bec providing power via the pwr module port, but I did not. Live and learn.
What I would like to see is a VCC failsafe. for instance, if a bec is providing power via the servo rail and is going above the 5.7v allowed it should trigger a warning, and not allow you to fly the copter. This failsafe can be manually overrided in the parameters, but for the casual public it should always be on. Maybe a warning at 5.6, and then completely prevent arming at 5.65?
Also, why would the auto-analysis not warn me of the high voltage?
Thanks for all your work! If I could write code, I would be all over this project.
Cheers!
Craig
14kg quad?what motors is that?
Using u10's on 12s. but I am upgrading to u11's now. U10's were a little bit underpowered.
Hi Craig, sorry for your crash.
Your idea for a servo rail voltage failsafe is a nice one. However it would not have saved you. The fact you would power also via the power port would not have saved you either. Why? Because if you get a voltage above 5,7V (short burst spikes for example which are frequent if you connect servos on the servo rail), Pixhawk will protect itself by shutting down.
So the only good way to avoid your crash was to follow what is written in the manual and plug a zener diode (trimming any spikes above 5,6v) on the servo rail.
Hope this helps,
Cheers
