Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Ignore this one please..., by putting the RC control channels in MNT_RC_IN values, it started working like V3.21 again, when MNT_TYPE = 1
Erik
thanks Randy for that, looking forward for the next release. By the way, would the new gimbal feature: "do-mount-control commands supported in missions" work if I use the traditional wiring for gimbal? or is it for gimbals which use Serial interface only?
@Erwin,
The mount-control mission commands should work for all gimbals.
The next release candidate (AC3.3-rc2) will definitely, 100% be out in time for weekend testing.
Txs for testing!
This may have something to do with setting mnt_type in the settings.
Mnt_type will need to be set these values:
Mount Type (MNT__TYPE)
Mount Type (None, Servo or MAVLink)
VALUE MEANING
0 None
1 Servo
2 MAVLink
3 Alexmos Serial
4 SToRM32
Best Erik
Hi Eric,
Thanks. I looked at MNT_TYPE, but thought that the "3" that was set there was the proper value. I'm not sure if the meanings changed in 3.3rc1 or what, but its working now when setting it to 1.
Some of the other changes in 3.3rc1 are visibly better, thanks devs!
Ok solved.., put your RC controlling channels in MNT_RC_IN_ROLL and MNT_RC_IN_TILT and your control from the transmitter is back...
In the camera Gimbal Settings under Initial Setup I have the same RC Channels, and stabilize on.., which appear to work as well (stabilization I mean)
Leave the input channels in this screen empty...
MNT_TYPE = 1, MNT_DEFLT_MODE can be anything, depending on what the control should be during auto missions.
Erik
There seems to be some confusion because there is a new MNT_TYPE parameter in addition to the MNT_MODE parameter. In your case the mode would be 3 but the type would be 1
MNT__ was a typo in the parameter description
Fixed now
https://github.com/diydrones/ardupilot/commit/85b0a18f610dc29c4cf96...
I do find a Mount default operating mode (MNT__DEFLT_MODE)
Mount default operating mode on startup and after control is returned from autopilot
VALUE MEANING
0 Retracted
1 Neutral
2 MavLink Targeting
3 RC Targeting
4 GPS Point
Which I do have at 3 (RC Targeting)
For the type I should make sense to put a 1 in there in case you work with Servo's like I do, but for the Alexmos serial it should be 3 correct ?
Or do we have a MNT_Mode somewhere?
Thanks !
Erik
Erik,
The MNT_DEFLT_MODE is the mode that the mount will be in when it starts up and after a mission is completed that makes use of the mount. So normally leaving that to "3" (RC Targeting) makes sense.
421
422
423
424
425
of 449 Next
