Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Gleb,
1. If you power off GPS1 it should switch to GPS0.
2. No. It simply relies on the number of satellites to determine which GPS to trust.
3. No, it's only fed the data from one GPS based upon the simple satellite check above. What you're implying is correct though, a better method would be for the EKF to look at both GPSs and determine more intelligently which one is better. That'll be an enhancement in some future firmware I expect.
Thanks Randy,
test :
https://www.youtube.com/watch?v=mpd6HZchtH4
Gleb,
Ok, thanks for that. I'd never seen how it responds in practice.
So it's a slightly messy transition as it switches from one GPS to the other. The sharp move is probably exactly the difference in position reported between the two GPSs. So clearly what we should do is when there's a transition we should move our target position as well.
-Randy
P.S. Slightly dangerous testing - it always makes me nervous when I see people that close to a flying copter. Maybe wear gloves next time or a suit of armour. Thanks for the data though!
+1 @gleb, many thanks for the test!!
Hi Randy,
Thank you in advance if you could make it more smooth since I had similar situation but ended with crash since it was switched to GPS1 from GPS0 right before I landed around 50cm above ground in Loiter mode when GPS Glitch occur.
Waladi
Spotted in 9) b) : "Allow control of camera zoom for upcoming IntelEdison/Sony QX1 camera control board"
I haven't managed to find any information on this. Has anyone got any details? It sounds very interesting!!!
Tobias,
This is something that Jaime Machuca has been working on (with some input from me). It's basically an intel edison with the sparkfun serial block and console blocks. It runs MAVProxy which has a new module allowing control of the Sony cameras using their wifi interface. I have one and it seems to work and I'm expecting Jaime will do a blog post in the near future.
Thanks Randy! I'm really looking forward to this blog post. Using the sony QX1 or QX10 will be awesome for high quality aerial photography with relatively small size copters.
What signals this new feature accepts (PWM/IO..)?:
"5) Aux channel features:
a) Emergency Stop - stops all motors immediately and disarms in 5 seconds"
I'm planning to try 3.3. parachute functions this week. 3.2.1 version parachute function didn't work.
Henri,
The emergency stop feature is controlled with a ch7/ch8 (up to ch12 now actually) auxiliary switch (i.e. set CH7_OPT to "31"). I think Rob or I will do a little video showing the difference between the emergency stop, the interlock and the stop/brake flight mode... Rob's away this week though.
