Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • MR60
        thx very much for doing the I2C test. So no difference in measurements between my measurements on Arduino & I2C /  Pixhawk & I2C. Does this mean there are no more issues with latest firmware 3.3RC4 using lidarlite on I2C interface & pixhawk ?
        I understand from this graph the 40 cm offset is confirmed on PWM.
          according to my measurements the I2C delivers very good results, being close to the expected value.
          PWM has an offset (I used the standard settings, as described in the wiki), which does actually increase slightly with distance (see the graph below).
          My understanding was that I2C could get locked up (due to the LIDAR-Lite sensor), and it was therefore recommended to use PWM instead of I2C to connect to the Pixhawk.
          3702785874?profile=original
            Felix,
            Really nice analysis.  So setting the RNGFND_OFFSET to 20 would bring the pwm and i2c values closer together although, they strangely don't seem to be exactly lined up even after taking the offset into account.  It seems like either the sensor or the pixhawk is not getting the pwm value quite right.
            I hear the LidarLite will not cause the I2C to lock-up anymore but it puts a nasty spike on the I2C line fairly regularly as it takes a reading.  That spike will apparently ruin other i2c traffic that's happening on the same i2c line .. that means some compass readings will be lost.  We've seen the spikes but we haven't confirmed it's effect on the compass.
            I'm going to set-up an optflow and lidar-lite on a copter next week so I'll go through the set-up in detail and see if I also run into some problems.
      Hugues,
      I talked about this with Tridge and Philip and they've also noticed the offset in the sensor.  For Tridge the offset was different for each sensor but Philip's three sensors all had an offset of about 40cm (similar to what you're seeing I think).  Could you try setting the RNGFND_OFFSET parameter to 40 (=40cm) to see if it correct the problem?
    • Hi Hugues, nice work as usual.
      Just to be clear, you were using the I2C interface to get the measurements on Arduino. And then you are comparing it to the PWM measurements on the Pixhawk?  I'm not sure this is a firmware issue, as much as it is likely to be analog signalling errors.  PWM is not digital, it is time-analog, and is subject to noise.  This is the cause of "jitter" on PWM RC inputs, and would be expected on a PWM range measurement as well.
      It's possible something can be done on the Pixhawk firmware to improve this.  But it might also be the best that can be achieved already.
      • MR60
        You are right, I tested with pwm on Pixhawk as the I2C interface does not seem to work yet. I am sure Randy and you will find the solution ;)
          The I2C interface on the Pixhawk does work, but the sensor / bus may lock up while it is being used.  Obviously not an issue for bench testing.
          It would be great if you could repeat your test using the I2C interface so we have that as a data point and can compare the I2C interfaces for both systems.
          • MR60
            Hi Craig,
            Yes that is possible but I'm at the moment ordering more pixhawks at 3DR (I'm a new reseller) as I am out of everything ! So I could only test with an arduino laying on my bench for the moment...
      • mmmh yes you might be right.. But from what I heard, most have about 40cm offset (+/-5cm). If its analog errors, does it not to have be more spread? I also have these errors just with pix and lidar powered and nothing else on the bench.
      Nice analysis Hugues.  So I guess we have some debugging we need to do on the px4 lidar-lite driver!
Aug 25
