Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
My bad, Its open for all now.
Thanks for taking the time.
Raviv,
I've had a look at the logs and it looks like a failure of the back right motor (#4). I think it's this because the actual roll and pitch are following the desired reasonably well but then suddenly separate. The throttle is not very low at this time so there's no reason to suspect it's the THR_MIN issue reported by IvanR.
The issues are the DCM vs EKF attitude estimates are off by >10 degrees and there is a portion in the log just before the crash where the vehicle's climb rate is negative but the baro and sonar alt appear to climb.
Thank You!!
I will rebuild it and post the log
Looking at the logs it seems that you were on the ground most of the time. Then when you did fly your VCC dropped a LOT as did your volts on your main pack. Your PDOP is all over the place and it looks as if you were moving it around a lot while it was initializing. It's kind of hard to read these logs all in all but all these things adding up looks like a crash was waiting to happen.
By the way, in the dataflash log's UBX1 and UBX2 messages there's some additional info including a jamming number (see field "jamInd"). Not sure but these may also provide some additional information when the GPS signal is facing interference from nearby electronics (like FPV equipment).
Dennis,
I'm not able to open the log in Mission Planner or APPlanner2. I think there may be an issue with the log file. Perhaps clear the logs completely and do the test again or maybe take out the SD card from pixhawk and plug it into your PC and copy the file directly to your machine instead of downloading over mavlink (which can be very slow).
Dennis,
For sure it depends on your location, but 10min and even 3min sound too high. In Germany it is always < 1min with an M8N - no matter is AC3.2.1 or AC3.3. So maybe something is wrong with your module?!
...outside...
Dennis,
Thanks for the report. Any idea which settings are being changed that cause the slower lock time? Would it be possible to run back-to-back tests with AC3.2.1 and AC3.3 with the Log Bitmask set to "Log while disarmed" so we can see the difference?
Sorry to be annoying but we have seen this type of report with releases in the past and often it's comes down to environmental factors that happened at the time of the firmware upgrade. Still, that may not be the case this time so if you have some more info that would help.
By the way, AC3.3 allows controlling some settings of the GPS using these parameters:
i ran 3.3rc7 for 20 flights or so and also with an M8N and didnt experience any of the issues that Dennis is seeing....I actually ran with two GPS, M8N as primary and 6H as secondary
261
262
263
264
265
of 449 Next
