Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Thanks for your reply and explanation. I have the controller mounted using only a double layer of 1cm squares of 3M 4010 double-sided gel tape at each corner.. After a couple years of 3S, I'm really enjoying this new found world of 4S capabilities.
it is an amazing product, it is true, and truly unbelievable effort.
Couldn't agree more.
You dev guys are great!
I think we all agree they are the backbone of this project and much appreciation to all of the Devs and contributors!
It happened again today - in a simple mode, position hold, all control directions were mutating making impossible to control the vehicle, I had to drop if down, thankfully, not from very high. 3.3 rc7 on a tarot 690s hex.
it flies pretty much great most of the time, so, not sure what this glitch is, it is not common, but it has happened before.
I could not reproduce it later, in the same spot and same flight path. if it has any practical relevance for review - here is a link to log, it is shortly before min6 mark.
https://www.dropbox.com/sh/7neu2qpw219c31x/AAAi_1auiWHRrBcDD5tYcxnN...
I will try to dig deeper into that. I flew aramttan in a same spot on my front lawn where I fly test tarot now, as I stopped tinkering on armattan for quite a while, but wanted to test a new battery. what is odd- it got same gps units, same controller, same number of satellites it gets, all seems same good, but, it does wander around much, much less than tarot in position hold. it is quite odd.
Paul,
You've used simple mode in AC3.2.1 and read the wiki instructions here right? I'm pretty sure you understand simple mode but I'd like to try and rule out operator error.
So it looks like you've got ch10 setup to turn simple mode on/off. So when it's off the pilot's controls should all be in relation to the vehicle's actual heading. When ch10 is on, the controls will all be in relation to the vehicle's heading at the time it was last armed.
It looks like the vehicle was armed pointing almost directly north. After take-off the vehicle was pointed east, then pointed south, the back to the east again. It was facing east when simple mode was turned on using ch10 so the controls would have switched to be off by about 90degrees. About 10seconds later RTL was initiated followed by an emergency stop.
While disarmed, ch10 was turned off again so when the vehicle next took off, simple mode was off.
Does this sound like the sequence of events?
I will try to reproduce it again. if logs do not show it, may be it was my own mental glitch, it is possible.
When I engage simple mode I always do small control inputs first to make sure I can control it and it goes where I expect it, in this case it was the same. then it just stopped going in the anticipated direction and I could not figure out how controls shifted, but, if logs do not show any errors, only way is to make sure again of what happened. I start from my driveway quite often, so, I will try again.
an operator error here could be if I actually moved myself, or turned 90 degrees after staying facing same direction when drone took off. it is probably possible, as I think of it now. unlikely, but possible. I will try again.
Used AC 3.3 AC7 today and it was flying great, then we started to test the Yaw. After giving a Yaw input it returned back to center and when it returned back both rear motors cut off and caused the quad to fall on it's back. This happened in stabilize mode.
Attached is the .tlog, I will attach the other logs when I can.
The crash happens at 93% on the log. Very strange.
2015-07-11 16-53-18.tlog
Definitely dataflash logs will help once you get them.
So my current theory is either the Yaw PID's are too low for this copter and it did not respond fast enough or something, or, looking at the "Clipping" in that log it seems to increase beyond 100. I am not 100% sure exactly what this means, especially from a .tlog, but have read about clipping causing issues.
Any help would be greatly appreciated, I won't be able to get the data flash logs until tomorrow.
276
277
278
279
280
of 449 Next
