Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • It uses a flight mode.  Initially, setting the flight mode directly didn't work correctly as some required initialization and cleanup wasn't done but that was fixed a while back.  I haven't checked lately, but last time I looked, this needed better documentation in the wiki.  It is important for people with 6 channel radios to be able to set it up this way.
        One small restriction with using the flight mode switches;  I believe you need to arrange the flight modes so you can go directly between altitude hold and autotune modes without a third mode between.  For example, if more than one switch is used to select flight modes, you need to be able to switch between autotune and altitude hold by changing just one switch and if it is a three position switch, one of the modes must be the middle position.
        --Brad
      It should be possible to do it using the MP's flight mode setup screen now that we've added AutoTune to the parameter descriptions.  In any case, it's "15"
      • Randy, Thank you very much for your reply. I had just reinstalled the MP to make sure that I had the last version. Actually I have the version 1.3.31 and the Flight Mode AutoTune do not show up on the Flight Mode list. And also is not mentioned on the Full Parameters List. Attached the screenshot. Should I have to open the issue on Mission Planne GitHub? Another question: The ESC calibration method is changed on AC3.3 rc8? I
        3702714403?profile=original3702714374?profile=original
        https://storage.ning.com/topology/rest/1.0/file/get/3702714395?profile=original
        • Sorry for double message.
          I have some browser problem in editing the last message. I'm very sorry =(
          I re-write evrything here:
          Should I have to open the issue on Mission Planner GitHub?
          Another question:
          Can I calibrate the ESC in the same way I do with AC 3.2.1?
  • Hi Brad,
    Are you using two (2) GPSs , or only One ?
    Because I had similar problems last week (Pixhawk Platform) with 2 GPS, but I don’t have more the logs.
    Then I "remove" one GPS ("without brand" . generic one ). and test again and again, without any problem.
    • Just one GPS
      --Brad
      • with only 1 gps system is very dangerous to fly. I had to put 2 gps units for this reason alone, as it is highly unlikely for both healthy GPS units to glitch with data transfer simultaneously. both vehicles I have are flying very reliably with dual gsp setup. without it - it would do a similar uncontrollable slip out sometimes, same as you saw.
        only downside with 2 GPS units is when signal is not good and one gps get replaced with an another your drone may 'jump' to the different location and then back, as it thinks it got moved as different gpc units receive slightly different coordinates.
        but it is a minor issue, and I do not think any system on 3.3 should be operated with a single GPS, as long as code is what it is.
        Randy stated above drone is expected to land - it does not. it will go sideways as described, with crazy speed, and you need to have a motor kill function ready to stop it from a fly away. it never happened to me after I got dual gps setup done.
        PS. Perhaps, for a dual GPS setup it would be nice to augment the code with some analysis of what coordinates each GPS unit reports and prevent this position adjustment done with a presumption that drone suddenly teleported itself from an old location into a different one.
        • The GPS glitch behavior you describe is quite different than what i saw this week, which Randy graciously pointed out were caused bad parameter settings.  I'm still investigating how they got set to 0.
          I used to have frequent problems with GPS glitches.  I moved the GPS up and farther away from the rest of the electronics and haven't had a single glitch since (perhaps 40 flights).
          --Brad
          • Well, i am not as concerned of what a reason was... What matters is a reaction of a platform to a sudden data interruption from a gps and i am sure only reliable solution in this predicament is to have a redundancy.
              By the way, in AC3.4 we can get rid of much of the twitch as it switches GPSs.  We just need to reset the target position of the copter by the position difference of the two GPS.  In Loiter the pilot will hopefully not notice any twitch.  In Auto you might see a shift as it realizes it's off the desired line but it'll be much better than now.
